Question about Polk Audio PA330 MOSFET Car Amplifier
Amp wont power up
I have power to the amp and the protector light stays on and the power light wont come on
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
L E D christmas lights stay on when shut off.
No it's not. Your LED Christmas lights are okay. Your surge protector is fine too although the switch on your protector is an SPST type - it is connected to one line of your AC outlet. When turned off, the line with the switch is physically cut, but the other line is still alive. Some LED circuits and TFL lights blink even when the switch is turned off, probably because one line of the AC power is still (a)live. If this worries you, just unplug the LED lights from the protector.
Nov 23, 2013 | Garden
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
PROTECTOR LIGHT STAYS LIT ON THE AMP, NOT POWER LIGHT
The protect light is on because there is a internal problem with the amp, causeing it to over heat,
Dec 02, 2012 | Audio Players & Recorders
How do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
Mar 06, 2010 | JVC KS-AX7300 Car Audio Amplifier
Amp repair
Check all your connections to make sure wiring is correct, if the light stays red you have an internal fault in the amp.
Jan 27, 2010 | Sony XM-SD46X Car Audio Amplifier
Red protector light
Try this first:
Amp in Protect - Troubleshooting
If nothing there helps, you need to return it to the seller if it's under warranty.
Let me know if you have any other questions.
Nov 16, 2008 | Car Audio & Video
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Nov 04, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
Polk Audio PA330 MOSFET Car Amplifier Logo
21 people viewed this question
Top Polk Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Polk Audio Car Audio and Video Expert? Answer questions, earn points and help others
