Why is my dimensions 2350 cpu box doen't work
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
It is either an intel pentium 4 or celeron
Posted on Feb 15, 2013
whitebirch
  • 433 Answers
SOURCE: desktop cpu shuts down shortly after startup
I if you haven't added any new hardware or software since this problem started check the following:
I would be thinking a heat problem. Check on the BIOS log looking for Thermal Events...check to see if the fan on your processor/sync. is tight and spinning. Check to see all fans are spinning and clean out dust. If you are satisfied that that is not the problem, look to your video card. Do a reinstall or update on the Vid drivers.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
It should be one of these two things...if not memory would be my next concern.
Posted on May 10, 2009
antiochpc
  • 1314 Answers
SOURCE: drivers for dell dimensions 2350
All drivers for your computer are here:
Note, sm bus controller is the chipset drivers. LAN is ethernet, audio is multimedia, and pcisimple is modem. There may be a couple different ones in a category, try each driver to see if they work.
Posted on Jun 18, 2009
  • 1684 Answers
SOURCE: My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 02, 2009
djtatty
  • 417 Answers
SOURCE: dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Posted on Aug 17, 2009
  • 13 Answers
SOURCE: how to remove and replace cpu for dell dimension
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Posted on Nov 24, 2009
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
How to remove and replace cpu for dell dimension desktop 2350
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 cpu fan failure
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
Drivers for dell dimensions 2350
i get most of my drivers from driverguide.com it is free
Jun 18, 2009 | Dell Dimension 2350 PC Desktop
Desktop cpu shuts down shortly after startup
May 09, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
