Question about Mitsubishi WS-65807 65" Rear Projection Television
Audio but only black screen for video on WS65807
Menu's work but all three colors are not converged so it's hard to read. There is no picture on the inputs but sound is fine. I've tried reset convergence but it doesn't make a difference and convergence menu doesn't show grid for detailed convergence. How do I factory reset?
  • jdey1
    jdey1 Dec 04, 2012
    while the information is correct the reset in the options menu didn't fix the problem. I did reset the menu's user entered preferences. Upon start up the led blinks three times (microprocessor is fine), and after performing self diag. I get 12 (no errors found). However, I still have a black screen with sound perfect on all inputs. I have not gone into any other hidden menus or performed any home repairs. Any suggestions?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
First, the set has a hard reset but it will NOT affect convergence which is stored in a separate area of the set.
Model indicated has 3 hidden menus---all accessed with the Original remote and a 4 digit code.
At your own risk:
This is a V17 chassis that was used in 8 models.
It has 3 hidden tech menus: With set on:
Option menu is 8270 enter---The Option menu reset will return all settings to factory and also will clear any glitches out of the way--it as stated can cause Convergence not to be affected.
Circuit adjust menu: (stay out as one wrong move and fatal things can happen is : 8257 enter.
Convergence adjust menu: (better than customer and SAVES adjustments made in to the DCU or digital convergence unit in the set.
I STRONGLY SUGGEST YOU TRY THE OPTION MENU FIRST, IF NEED DETAILED INSTRUCTIONS I CAN LOCATE THEM FOR STEP BY STEP OF THAT.
SEE IF IT CLEARS THE MAIN ISSUES UP FIRST---IF YOU TRIED TO ADJUST CONVERGENCE IT MAY NOW BE MESSED UP BUT UNLESS YOU GET THE SET BACK TO WORKING SOMEWHAT NORMAL NOTHING TO WORRY ABOUT.
keep in mind I do this here for free and have worked on hundreds of these Mitsubishi sets.
SD TECH------ASK BEFORE YOU LEAP!
Posted on Dec 02, 2012
3 Suggested Answers
electronick
  • 505 Answers
SOURCE: Mitsubishi ws-65809 Convergence will not align correctly
You may also have a resistor burnt out for the convergence ICs.. They are all right in front of the ICs and will usually show browninsh if burnt up. If bad, replace the pair and maybe the ICs as well if they've failed again. If your new ICs fixed the lines so they'll move, then you may have problems with the centering magnets on the yokes of the crts. Dont move the yokes or magnets if you can help it, but look to see if some of the manufacturers glue broke free and let the magnet spin around the neck of the tube. If so, try to put it back where it was and then re-converge.
Posted on Dec 06, 2008
  • 336 Answers
SOURCE: have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Posted on Mar 29, 2010
Video 2
Projection sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3d, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from www.TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
You can also read more about this on the tips page here on Fixya. Here is the link.
http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Apr 21, 2012 | Hitachi 51F500 51" Rear Projection...
Convergence instructions
Projection sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3d, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
  • Screen looks 3D
Feb 05, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Magic focus
  • Screen looks 3D
Dec 23, 2011 | Hitachi 51F500 51" Rear Projection...
Mitsubishi rear projection picture that has a blue/green tint
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
  • Screen looks 3D
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 01, 2011 | Sony Televison & Video
I have a 63' projection TV. The picture is off. All of the lights are working, but the images are fuzzy, and you see the image tripled. The three images overlap each other in red, green, then blue. ...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2011 | Philips 55PP9363 55" Rear Projection...
Convergence is gone from the menu
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 25, 2011 | RCA HD52W66 Projection Television
Wave & three colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
