Question about Acer Aspire 5100-3357 Notebook
Matshita DvD ram uj 851s ata device is delete of my pc
Matshita Dvd-ram UJ-861H ATA Device Not Working
Use this link to find possible answers to your problem. It is in the Microsoft Community
HP Pavilion with Vista Matshita Dvd ram UJ 861H ATA Device is disabled...
Feb 20, 2014 | Computers & Internet
My HP Pavillion dv6560oe can not install the driver for the MATSHITA DVD-RAM UJ-851s ATA device. The device has stopped functionning (code.10)
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 26, 2011 | HP Computers & Internet
Uninstalled matshita dvd-ram uj-8505 ata device
Go to Control Panel, Add Hardware and Windows should do it for you.
If you are PC literate go to Start click on it go to My Computer nad right click on ot go to Hardware and click on it go to Device Manager and click on that scroll down to CD/DVD and click on that select the DVD unit and select update driver
Jan 14, 2010 | Sony VAIO VGN-N365E/B Notebook
Matshita dvd-ram uj-851s ata device vista
Foolw the guide below, this will edit the registry, making the device visible and useful again.....
Windows Vista
1. Click Start
and then click All Programs.
2. Click Accessories, and then click Run.
3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5.
6. In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
7. On the Edit menu, click Delete.
8. When you are prompted to confirm the deletion, click Yes.
9. In the right pane, click LowerFilters.
10. On the Edit menu, click Delete.
11. When you are prompted to confirm the deletion, click Yes.
12. Exit Registry Editor.
13. Restart the computer.
Oct 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
System not reading my matshita dvd ram uj - 850s ata device
If you are using genuine microsoft OS the download the Microsoft User-mode Driver Framework Feature Pack1.0.0 (Pre-release5348) from microsoft corporation or from CNET driver update tracker....sodeep
Mar 17, 2009 | Acer Aspire 5100 Notebook
MATSHITA DVD RAM UJ-850S Device Not Even Shown
Try a Google search for the driver. I got my printer driver that way. Prints just fine.
Feb 14, 2009 | Computers & Internet
Matshita DVD-RAM UJ-851S
here's the fix
http://msbin.com/kb/entry/53/
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Dec 24, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Does my Matshita DVD-RAM UJ-850S ATA Device support DAO/96 mode?
yes, yes and yes. DVDRAM drives do pretty much everything.
Oct 27, 2008 | Computers & Internet
Acer Aspire 5100-3357 Notebook Logo
927 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
