Question about HEWLETT-PACKARD Hewlett Packard HP Mini 210 with 160GB HD; 1GB Memory Hard Drive
Laptop screen wont boot
Laptop boots up as you can see lights an hear fan running but screen wont boot. caps lock is locked on. ive tried external monitor but this didnt work. there are no sounds that you usually hear from start up. HELP
  • HEWLETT-PACKARD Master
  • 2,072 Answers
If you don't see the initial BIOS screen you could have a problem with one of the following.
  • A bad motherboard
  • Bad memory
  • In some cases a bad Hard drive
Remove the hard drive and memory (both typically removed from panels on the back. Try rebooting. If you get the HP BIOS screen then either the memory or hard drive is bad. Add each back in one at a time and reboot until you find the problem device and replace. I would also power on the computer and use a flash light on the screen. If you see a faint image of what you should normally see then you have a bad inverter. Lastly your motherboard is bad, not a lot you can do to test that.
Posted on Dec 02, 2012
Help Black screen fan but no hdd light
No display and not booting after getting very hot is likely to be a GPU issue. This is repairable.
Jun 02, 2014 | HP Pavilion g7-1310us 17.3" Laptop
The screen will not power up on my hp pavilion dv7 4065dx
Count the blinks and pattern of the caps lock light flashing. They tell the technician what is going on with the system. If this is happening as soon as you press the power button you are probably having an issue with the Video Card, Memory or some other motherboard related issue.
Does the system seem like it is up and running? If not, it's definitely one of the three issues mentioned above.
Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop, then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.The link below will gives you the blink code listing from hp website. When it opens up scroll down to to see what the blinking lights pattern means as to the cause of your system not booting.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
Apr 18, 2012 | Computers & Internet
Toshiba Sattlite, boots but black screen. Caps Lock light is on and F10& F11 key is okay.
Corrupted operating system. Start over with a restore disc and if you do not have one buy one you will need it from the factory. Re-install the whole system over again. Insert the disc in the slot and power it on select boot from DVD or CD-Rom which ever you have. Follow the onscreen instructions. John
Apr 09, 2012 | Toshiba Satellite L305-S5907 Laptop
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Rhp g61 laptop screen wont boot up, i can hear the fan, and the power and caps lock are lit what the matter
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps.
If you need more information, reply me soon.
Thanks
May 18, 2011 | Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Laptop turns on but no display
Couple of things, try an external monitor on the back connector, disconnect the battery and ac adaptor for a few hours and try again, find the reset button in a hidden hole in the laptop case (may not have one) Boot the computer without the battery installed only the ac adapter.
Oct 27, 2009 | Acer Aspire One PC Notebook
Acer wont boot blank screen and external mon blank
When this laptop was dropped it possibly damaged to Graphics Card on the motherboard. Without a engineers visual inspection it would be difficult to say.
Jun 19, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
HEWLETT-PACKARD Hewlett Packard HP Mini 210 with 160GB HD; 1GB Memory Hard Drive Logo
88 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
