Question about Watches
Set time and date on Oreex WR30m watch - Watches
5 Suggested Answers
  • 5 Answers
SOURCE: Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
Posted on Mar 25, 2008
SOURCE: Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Posted on Apr 03, 2008
  • 11 Answers
SOURCE: How do I set date & time?
usually breitlings have a screw-in crown with a gasket for diving. If you cannot pull the crown away from the case, try unscrewing it. After a little pressure to the left, the crown should begin to turn. Unscrew it carefully and you should be able to pull it out one stop for the date and all the way (note second hand stops) to set the time. Be careful pushing it back in and screwing it back down. You don't want to potentially damage the threads. The crown is back in place when you ca't screw it in any more and the "B" is straight up and down
Posted on Jul 06, 2009
SOURCE: Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Posted on Jul 29, 2010
How to set the time on a wr30m watch
google how to set time on a wr30m watch
Sep 10, 2016 | The Watches
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 | Watches
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
How do I change the time on my watch?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 16, 2010 | Casio LA11WB-1 Watch for Women
Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Mar 07, 2008 | Watches
Dec 03, 2007 | Watches
Watches Logo
226 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
