Question about Kenmore Washing Machines
My washer won't spin. it's been in storage for 5 yrs and ran just fine at that time
It sounds good, it just stops when it's time to spin
    Sergeant:
  • 198 Answers
Am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!!
Posted on Dec 02, 2012
  • 2468 Answers
SOURCE: Have Fisher & Paykel washer GW11. 5 yrs old.
your door needs to be re-aligned so the wax motor assy can lock the door so the unit senses its locked and can continue the wash cycles
Posted on Jul 16, 2010
Macmarkus
  • 2605 Answers
SOURCE: my washer was flashing F21
Hello, welcome to FixYa.
Based on your description specifically the door not unlocking combined with the F21 or as you stated "F21 & would not unlock" I'd suggest you check the pump filter and sub-components, i.e. back flow ball, drain hose etc.
Here's a link to my solution or explaination to guide you through checking these things. Typically this is associated with an error of F2, F21, or "suds" but not always.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
As for unlocking the door, it's a good idea to get the water out first, but in any event to do so is as follows...
Once you remove the service panel at the bottom, shown here (also shown in my "repair tip")....
...there is a manual latch release just below the lock latch assembly that you may be able to see visually or feel for by reaching up to the latch and pull the small "loop" below the lock...this is a image of what you'll be looking for.
Let me know how you make out or if anything is not clear and I'll try to help you moving forward in any manner I can. Good luck.
Please take a moment to rate the info and provide a testimony on my assistance and your experience here at FixYa.
Regards,
Macmarkus :)
Posted on Jul 14, 2011
mc1bean
  • 3053 Answers
SOURCE: Good evening, My Roper
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Posted on Jun 09, 2011
  • 500 Answers
SOURCE: my washer will not spin,
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Posted on Jul 18, 2011
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Bravos washer stopped on the spin cycle
You might have items between tubs. Are you using HE soap in the correct amount?
Service manual
Posted on Oct 29, 2011
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
Machine just won't start
you have probably a bad lid switch
Dec 28, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
305 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
