Question about Peg Perego John Deere Gator HPX
My hhpx gator wont start and hydro locks when trying to start
2002 gator hpd with kawasaki engine . ive adjusted valves at 10 and 10 , cleaned out carb , changed plugs and checked all spark
  • matt06 Dec 02, 2012
    2002 gator-i have spark so that should eliminate the module / computer. I can say that as i turn the key the spark sometimes stops. Are these older gators known for braking the keyway on flywheel?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
This is the forum for the toy gators
Posted on Dec 10, 2012
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: i got a john deere gator 4x4 hpx, it will not run
Remove flywheel shroud to see your timing marks,they will be 90 degrees apart on face of flywheel.Use timing light on flywheel as you look directly at it from the side.when light flashes you should see the marks lined up with arrow at the center top of block breather cover.If you find that your timing is off there are only 2 things that it can be-FLYWHEEL KEY or the computer located at the rear of engine.I have only had 2 machines where the timing was off exactly 90 degrees and the computer had to be replaced both times.
Posted on Mar 05, 2010
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Wont start water in cylinder
You have hydro locked cylinder , blown head gasket , cracked engine block , cracked cylinder head etc... Engine probably needs to be rebuilt ! Bent rods , valves etc....
May 22, 2015 | 2002 Kia Optima
Hi, ive got a 1999 g2 kawasaki zx6r been sat for 6 months+. ive changed plugs,battery, petral and pilet jets becoz to blocked, so put like for like back in. it only starts of bump and backfires realy bad...
Have a professional carb service and valves adjustment done.
Just replacing the idle jets will not clean the entire idle circuit. Mixture screws need to be removed, circuit needs to be cleaned out, re-installed,and properly adjusted for idle mixture.
If backfire continues valves need adjusting. Best to do both at same time to save on labor.
Apr 04, 2014 | kawasaki Motorcycles
I have an ATV 2000 Yamaha Kodiak YFM400AM(C). A few months ago after warming up it stalls when I PUT IT IN GEAR. I had to adjust choke idle up to engage into gear and go. It still does that and now when I...
For the first problem. Most likely the clutch is holding to tight and needs to be adjusted. Next problem. Check this first. Check the
connections on the battery post, make sure they are clean and tight. Next the carburetor may have flooded and hydro locked the piston. Make sure the battery is fully charged and the battery post are clean and tight. Retry starting the engine, if you only have the clicking sound, move the ATV to a location where gasoline cannot be ignited by a flame or spark including the sparkplug wire. Remove the sparkplug, move the sparkplug wire into a location where it is not close to ground so it will not create a spark. Try to crank the engine and see if it will spin, if it spins it will spew out gas if it was hydro locked. If the engine was hydro locked crank the engine a little more expelling as much gas as possible. Leave the spark plug out for a while so the remaining
gasoline in the cylinder will have time to evaporate. Clean and
reinstall the sparkplug. Try starting the engine, if the engine starts, reset the adjustments you made to the carburetor prior to having the dying problem. If the engine was not hydro locked and will not spin, and you only hear the clicking sound when trying to start the engine, you may have a problem with the starter or starter solenoid should it have a solenoid. I do think the engine will be hydro locked. Provided the battery, was fully charged the battery terminals were clean and the starter circuit is ok.
Ge
Oct 30, 2013 | 2004 Yamaha XT 660 R
Engine wont start
Its possible you got enough oil in one cylinder to make the engine hydro-lock. That is a condition where something liquid is in the cylinder and will not allow the piston to travel from top to bottom.
You may have broke the timing belt.
May 03, 2013 | 2002 Mazda Tribute
Kawasaki zxr400bike been stood for a while started after a couple
Backfires may indicate that a valve is sticking open, so that you are not getting compression. I am assuming that no repairs or adjustments were done which might have messed up the timing of valves or ignition.
Jan 01, 2010 | 1989 kawasaki ZXR 400
Peg Perego John Deere Gator HPX Logo
123 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
