Question about Toshiba TLP-LT8 Projector Lamp for TLP-MT1
Toshiba mt1 image ghosting
Hi there i have a toshiba mt1 projector recently fitted a new lamp but the picture on the projeted image is ghosting even when in menu mode the text is double imaged is there anything i can do to remedy this problem? or is it not cost effective to rectify? thanks...
SOURCE:
MikeNJ1964
  • 398 Answers
SOURCE: double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Posted on Sep 11, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba TN50V71
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE: Toshiba TDP D2 Projector
A mirror got loose in the opening from where the bulb sends the light to the "panel" It is blocking part of the light.
I'm not talking about one of the tiny mirrors that makes up the DLP, but there is silver box where the bulb light initially goes. the walls are lined with mirrors whose adhesive fails when exposed to great heat.
I can easily fix it, as i have fixed many of them from this problem.
Posted on Aug 26, 2008
nicknovikov
  • 101 Answers
SOURCE: ghosting, double images on my Toshiba rear projection TV
conv.out.ic(2).resistors:low imp.
Posted on Jun 27, 2009
projdoc
  • 2237 Answers
SOURCE: I have a toshiba tlp 770 projector. The image is
first, reset the settings to factory default. if you are using it with a computer, make sure it matches resolution. native for the projector is 1024x768, but maxes at 1600x1200. and the input is analog, not digital. if you are doing video, make sure you are on the correct video input. it does do hdtv, but not 480p or 480i. if none of this helps and the focus does not work, check case for signs of damage. maybe the previous owner dropped it and damaged something internal. last possibility: clean it out using compressed air. take the top off if necessary. since it is an lcd projector, dust and dirt build up on lenses and light filters causing them to burn. remove the lamp and look at the fly-eye lens inside the lamp housing. if you can see the one behind it, check for burn marks. there may be parts that need replacing.
Posted on Aug 18, 2009
Loss of good colour constant blue ghosting to picture, tried adjusting colour and gamma settings, no luck new lamp fitted still same problem. reset to factory settings picture gets worse? help
This will require a technician to repair.
You can do it yourself if you have the service manual and some knowledge of electronic repair, and access to the necessary parts.
It's generally cheaper to buy a new unit than to have one repaired though, unless of course it's under warranty.
Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Lamp
Hi Striker 53
Yes , a flickering image and dimming is a very clear indication that the lamp is going.
To make 100% sure and to give you some peace of mind - take out the lamp and you will either see vein like looking marks on the lamp or discolouration or even that there is a bubble at the end of the lamp's shaft.
Do keep in mind that a lamp normally gets a rating of say 2000-3000 hours , but that is only a estimate from the manufacturers factory. I've had lamps that had less than 300 hours on them , that needed replacement.
Once you replaced the lamp , remember to reset the lamp timer.
Apr 20, 2008 | Toshiba TDP-MT200 Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
RGB not aligned so I get thin red vertical stripes displaced to right of icons
If you are handy with allen wrenches, quality screw drivers, and the like, you might 'try' opening up the can of worms and gently manipulating the red LCD panel (it will be obvious--a magenta color when off), by slightly loosening the holding screws, then moving--ever so slightly, the panel untill the ghost disappears. Do not do this though, untill you mark the present position on the top and bottom of the LCD panel. Take pictures, far and close-ups, as you go so you can reassemble the unit. The typically three LCDs can be located by finding the prism cube, located under the circuit board, and just before the output lens. Be patient, and have fun. I did this with an 'out of wack' throw away, and now it is just as enjoyable as my 'dimmer' HDTV projector. Even side by side, from 8 feet away, when both are making 72" images, the HDTV is barely clearer, Jon.
Mar 31, 2007 | Polaroid Polaview 211E Multimedia...
76 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
