Question about Hitachi 55HDS69 55 in. Plasma Television
Tengo una HITACHI 55HDS69 hace poco tubimos a mi bebe q jugando con el control Desaparecio la imagen pero logramos escuchar el Audio , Pero mi esposa piensa que puede ser por el apagon que ocurrio ese dia
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
Problemas con el audio
Most likelly your signal board is going out. Since you have video but no audio.
You can get parts for this tv at www.interliquidparts.com
Dec 17, 2011 | Fujitsu Plasmavision P42HHA30WS Television
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
PROBLEM CON SOUND AND TV
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
Sep 07, 2007 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Hitachi 55HDS69 55 in. Plasma Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
