Question about Kenmore Washing Machines
Problems with kenmore elite model 11049962 603
What does F20 mean
  • 156 Answers
SOURCE: F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Posted on Feb 28, 2008
SOURCE: Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Posted on Aug 09, 2008
  • 1028 Answers
SOURCE: error code f20 kenmore elite 5ht washer
remove bottom cover and clean pump
Posted on Nov 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Posted on Jan 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: Code F20 is appearing on me washing machine
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 26, 2009
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
Frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Jan 20, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
What does the F20 flashing code mean on whirlpool duet washer
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 code.
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
