Question about Maytag Neptune FAV9800AW Top Load Washer
Why when washing machine ends cycle it keeps leaking water
    Sergeant:
  • 198 Answers
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Posted on Dec 02, 2012
  • DAVID
    DAVID Aug 16, 2014
    WHERE IS THE DRUM SEAL AT
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
gwshaw71
  • 83 Answers
SOURCE: Water leaking under washing machine
check your water pump , and tub seal.
Posted on Dec 07, 2007
  • 96 Answers
SOURCE: washing machine
Posted on Feb 26, 2008
SOURCE: water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Posted on Dec 31, 2008
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Water Leak?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Mar 08, 2013 | Washing Machines
Water leaks with larger louds on kenmore front load eco
Feb 01, 2013 | Kenmore Washing Machines
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
Roper #ras8245eq1 leaks during spin cycles
Check for tips on the link below to identify parts and removal:
Dec 30, 2012 | Washing Machines
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
MODEL NUMBER CAWS9234BQ0 CROSLEY Washing machine water leaking
Sep 03, 2012 | Crosley Washing Machines
Maytag washer sav205daww leaking water from bottom of washer when runinning
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.Also check on this link : http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jul 02, 2012 | Maytag Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Water leaks when draining
sounds like the drain pump is leaking
Feb 21, 2010 | Washing Machines
Maytag Neptune FAV9800AW Top Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
