The tub wont drain - Washing Machines
    Sergeant:
  • 198 Answers
Now for the repairs -
1. Remove all the clothing that is in the washer.
2. Remove all the water you can via a siphon hose technique.
3. Remove drain line from its drain and put it in a shallow bucket on floor and drain out whatever water it may have. Turn off cold and hot water feeds and remove drain lines. Drain water from them.
Now for the hard work - a helper is probably needed. You may wish to take digital photos of things before you take them apart so you get them back together properly later (I strongly recommend you do this). Get the tool box, a flash light, and an extension light out - you will need them.
4. Tip washer over on its side - and watch for and collect any water that it may have still in it. Remove the drain hose from the water pump (the drain hose connects to the pump). Remove belt from water pump. Remove water pump and take it apart. Make sure nothing is blocking the pump itself (a laundry item may be there); reassemble pump and make sure it spins freely at the belt pulley. Check the drain line from tub to pump - and make sure it is clean. You usually have to also remove the solenoid valve that is opened to permit draining as well - just follow the line to the tub. Make sure solenoid valve feed line has nothing blocking it. Once the entire drain line, drain solenoid valve, and pump are clear and clean, reconnect everything properly. Return washer to upright position. Connect water hoses and drain line.
Posted on Dec 02, 2012
  • JULIEN LABASTIDE May 15, 2013
    THANK YOU I WILL GIVE A TRY
Washer didnt drain all the way and now i keep gettin a code. n the light for the door lock wont come on
If water is in tub and the control tries to drain tub but water doesn't drain, then the unit will not operate. Most LG have a drain pump clean out located behind the access door on lower side of washer. Open the door and you will see a black tube with a cap and a round knob. First, get a bucket, pull the black tube slightly out and remove cap. The water in the tub will start to drain and you may have to fill bucket many times to get all water out. Next, unscrew knob and a little screen will pull out. Inspect this screen and inside of pump chamber. Your looking for any thing that could block the pump. If pump hums and still doesn't drain, the drain pump is more than likely bad. Good Luck
May 25, 2016 | LG Washing Machines
What will i do my american home washing machine AWF 706WS wont continue to operate to rinse and spin? I dont know how to drain the water
to drain the tub ,just put the drain hose lower than the tub
as for the rest have a technician check the program board
Oct 22, 2015 | Washing Machines
My kenmore top load washing machine washes but wont drain or spin
The spinning cycle may be detecting that your tub is unbalanced and will not proceed. Check that it starts and fails when the tub is spinning slowly. Otherwise you may have a faulty drain relay or debris is plugging the drain out hose.
Feb 01, 2015 | Kenmore Washing Machines
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 12, 2009 | LG WM2016C
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
DRAIN
I take it that you removed the drain trip linkage and stopper through the vent hole .
You must now run a small hand or small power snake the less than eight feet to open the drain.
You can also plug up the vent,tightly and  try a flat plunger on the tub drain .
Apr 20, 2009 | American Standard 1583.470 Universal...
Water wont drain out of dishwasher
This osunds like it could be the pump that evacuates the water out of the tub or there is a solenoid that activates thus allowing the water to be removed.
Dec 25, 2008 | Dishwashers
Washer wont drain water
It won't drain If your washer won't drain, check these:
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
