Question about Sony PlayStation 2 (PS2) Console
Playstaion 2 dc power socket broken
The mains supply plug (power socket) on the ps2 is broken. i have look everywhere but i cannot find any similar part. can someone please help
Amazon.com sells replacement cords, so does ebay
Posted on Jul 13, 2007
  • 80 Answers
I sujest you call playstation and tell them if they can fix it or if you can buy the part hope it helps.
Posted on Jul 03, 2007
I can't get power on my Casio lk-50. ? Help
Hi, There are several common reasons why this and most similar keyboards have this problem.
If you can fit known good batteries, and it works, this confirms the problems will be with the external power supply or connection.
Usually batteries are not available, so.......
Do the obvious.
  1. Is the power supply plugged into a known good mains socket?
  2. is the mains socket switched on?
  3. is the power supply plugged into the keyboard?
  4. is the keyboard switched on?
If the power supply is not the one supplied with the keyboard, then check it is compatible.
(You do not have to buy an expensive replacement power supply, a universal, regulated one, with a selection of connectors will be fine. Supermarkets and the like sell them.)
The manual, or a label on the bottom of the keyboard will tell you the voltage, current consumption, and whether the current is AC or DC.
Invariably the current is DC.
All the Casios I have are 9 Volts, (9V) and very few are more than 300 milli amps (300mA) More milli amps is fine, so the current can be the same or greater.
A TYPICAL power supply is likely to be:-
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
The power supply needs to be REGULATED.
Polarity
This is the way round the connector is wired.
Usually the center is negative (-) and the barrel is positive (+)
This information is molded into the plastic or on a label next to the socket.
On a replacement (universal) power supply, there will be a set of connectors, and when you have selected the correct one, the arrow on the end of the lead should point to the correct polarity symbol on the connector.
Fault finding
The most common fault is the power connector being broken or the solder has been broken.
Slowly moving the connector round, to find it works in some positions, is a sure indication that is the fault.
Repair is quite simple, but there are a lot of screws to take out.
Ideally, drill a hole in the case, where convenient, and fit a metal connector. Now connect to the PCB, in place of the original socket, with flexible wires.
Other wise if it is just solder failure, re solder and glue the socket with epoxy resin (Araldite) or hot glue from a glue gun.
Hope this helps, Chris.
Mar 15, 2016 | Casio Music
When I connect the dc plug into the laptop the laptop shutsdown
I have had a similar problem. If the battery is not holding a charge, then something is wrong with the charging circuit inside the battery pack. Remove the battery pack from the computer and reconnect the power supply and see if it stays on. If not you will need to check the voltage for the power supply.
Mar 05, 2015 | Lenovo G505 59371430 AMD E1-2100 1.0GHz...
WE CAN NOT USE OUR CASIO KEYBOARD NOR FIND A POWERCORD #AD12ULWK1630 anywhere
Hi, This is a copy and paste from a similar question, please excuse my laziness........
Do the obvious.
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
Polarity
Fault finding
Oct 20, 2014 | Casio Keyboard Power Adapter
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
My dell dccy will not power on. It was working fine and was powered off but will not power back on. I have checked the power cord. I have opened the case and reseated all connectors. Pushing the power on...
Yes, it's called bypassing the Power On switch. Has nothing to do with the switch itself, or it's wires.
You use a jumper wire on the 20 or 24-pin ATX main power cable's connector.
Touch the jumper wire from the Green wire (Soft Power On) to ANY Black wire. (Ground)
(Soft Power On is abbreviated as PS_ON)
If the Power Supply comes on, the problem is the Power On switch.
If the Power Supply does Not come on, the problem is the Power Supply.
1) 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
2) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Look at the photos of the ATX main power cable plugged into the motherboard.
Where the wires go down into the connector is the Back of the connector.
This is where the jumper wire goes down into.
The jumper wire goes down into the socket hole, in the Back of the connector, RIGHT NEXT to the wire IN the socket hole.
The jumper wire has to go pretty far down in the socket hole.
[ATX power cable plugged into the motherboard, Power Supply plugged into power ]
At the end of every wire in the ATX main power cable's connector, is a metal terminal.
A Female Molex Crimp Terminal connector,
http://www.alibaba.com/product-gs/336134982/molex_female_crimp_terminal_connector/showimage.html
[You can click on the Zoom In icon { + } at the top to enlarge the view]
The jumper wire Must touch that metal terminal.
The jumper wire is made from a straightened out paper clip, bent into a U shape.
The middle of the U is wrapped a few times with Black plastic electrical tape.
This where your fingers hold onto the jumper wire.
(One wrap of Black plastic electrical tape is good for 600 Volts DC)
One 'leg' of the U shaped jumper wire goes down into the socket hole with a Green wire.
The other 'leg' of the U shaped jumper wire goes down into ANY socket hole with a Black wire.
(ALL Black wires are Ground wires)
The contact period made is no longer than 2 seconds.
The Voltage is 5 Volts DC.
Two flashlight batteries produce 3 Volts DC.
This is one generic ATX power on switch that I have found fits many computers,
http://www.directron.com/atxswitch.html
NOTE*
WATCH IT when buying an aftermarket Power Supply for your computer, if it needs one.
For a time period Dell was strictly a Proprietary computer manufacturer.
Dell wanted THEIR parts used in THEIR computers only.
They had the motherboard manufacturer switch the pins around in the ATX main power cable connector, on the motherboard.
They also had the Power Supply manufacturer switch the power cables around in the Power Supply.
This means if you plug an ATX main power cable, from an aftermarket Power Supply, into one of these proprietary Dell motherboards, you WILL fry out the motherboard!
Can also fry out the Processor, Ram Memory, and Harddrive. (Plus a graphics card if you have one installed)
CHECK the color code of the aftermarket Power Supply's ATX main power cable, to the color code of the Dell power supply.
See that the color code of the wires matches the socket holes in the connector.
Have further questions regarding this, post in a Comment.
Regards,
joecoolvette
Nov 29, 2010 | Dell Computers & Internet
My computer will not turn on.
Suggest you start with checking the receptacle in the surge protector, that the Computer is plugged into.
I have had 3 surge protectors now that just THAT receptacle was bad.
"Hmmm, surge protector LED power on light is lit.
Monitor, printer, and router, plugged into the surge protector have power."
Plugging in a lamp into the receptacle in the surge protector, that the computer was plugged into, proved just THAT receptacle was bad.
Not an issue?
Then I suggest you check to see if the problem is the Power On switch, or the Power Supply.
The Power On switch is located inside the plastic Power On button.
This is an example of a generic ATX Power On switch,
The test is to use a jumper wire for the Soft Power On, and bypass the Power On switch.
Bad Power Supply.
Dell Support, and the Service Manual main page, for the Dimension E310,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
If you click on Technical Overview, then on System Board Components, you'll be taken to this page,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/techov0.htm#wp1058089
Here you will see an illustration of your motherboard. This is a Top view. The view you will see when you open your computer case.
(Main menu - Removing the Computer Cover)
The number 9 points to the ATX main power connector on the motherboard.
Viewing closely you will count 24 socket holes.
12 on top, 12 on bottom.
This connector is a 24-pin ATX main power cable connector.
If you scroll down the page to the heading - Power Supply DC Connector Pin Assignments, and to the heading underneath - DC Power Connector P1, you will see the Dimension E310 has a 24-pin ATX main power cable.
This is a more in-depth view of a typical 24-pin ATX main power cable, and it's respective connector, plus a view of a typical 24-pin ATX main power cable connector, on a motherboard,
(Not a Dell Dimension E310),
The photo to the far Left, shows a 24-pin ATX main power cable connector, on a typical motherboard.
There is no 24-pin ATX main power cable plugged in.
The photo in the middle, shows a 24-pin ATX main power cable.
The photo to the far Right shows the 24-pin ATX main power cable plugged into the connector.
In the photo to the far Right you will see that one of the power wires has Green insulation.
This is the Soft Power On wire.
Also abbreviated as PS_ON
You will see many wires with Black insulation.
ALL of these wires are a Ground wire.
The jumper wire is connected to the Soft Power On wire, (Green), and to ANY Ground wire. (Black)
The method is to insert one end of a jumper wire, into the socket hole with the Green wire, and the other end into a socket hole with a Ground wire.
(ANY Ground wire)
Again looking at the photo to the far Right, you will see that the power wires go down into individual socket holes.
The insulation of the power wires goes down into the socket hole pretty far.
At the end of each power wire is a metal terminal. It is a female terminal.
This is what it looks like,
http://www.alliedelec.com/search/productdetail.aspx?SKU=8630463
The jumper wire must go down into the socket hole, (Right next to the existing wire already in the socket hole), far enough to touch that metal terminal pin.
it has been suggested to use a paper clip.
The paper clip is straightened out, then bent into a U shape.
The center of the U shape is wrapped with black electrical tape.
The taped area is where you hold the 'jumper wire'
You may wish to wear a glove also.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
There may be a spark.
Hence I advised wearing a glove. Not so much for your safety, but for your peace of mind.
One end down into the socket hole with the Green wire, (Soft Power On), and the other end down into ANY socket hole with a Black (Ground) wire.
The contact period used is no longer than 2 seconds.
If the Power Supply comes on, you have a bad Power On switch.
If the Power Supply does Not come on, you have a bad Power Supply.
The Power Supply can come on, and still be bad. Weak voltage power rail.
Enough power to light LED lights, and perhaps spin fans, but not enough to turn the Processor on.
1) ALL of the LED lights combined, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Post additional questions in a Comment.
Regards,
joecoolvette
Sep 13, 2010 | Dell Dimension E310 PC Desktop
PS2 bad power supply
Greetings Xwrongwayx,
My suggestion is if it will plug into the newer unit, then it is fine to utilize the older power supply. I have two different PS2 units, and we use the cords for either to plug the units in.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 16, 2008 | Sony PlayStation 2 (PS2) Console
Wireless Guitar for Playstaion 2
If you have a wireless system than you have a battery in the plug in connector ,check that and make sure your able to get sound through that connector with a cord first.Please leave a Rating!
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Read disc error
i had the same problem with mine it's just that you playstaion is broke you need to have a new one i know why don't you ask for one like i did thing about it somthing good comes out of it you get to have a new playstaion
Aug 24, 2007 | Sony PlayStation 2 (PS2) Console
PS/2 power supply connection
You seem to have an oddball monitor if what you describe is correct. The power supply to a monitor[Display Screen is that what you mean?] is either direct to main power- in which case the power cord is either built in with a power plug for wall socket, or has a socket on the back for a separate main power cord. Or is powered from a low voltage converter that delivers low volts usually via a coaxial plug like this illustration PS2 connection does dot come into the equation as far as I know unless you have got hold of something unusual. Tell you what take a shot of the back of the monitor and lets have a look see mean while here's is a shot of a typical low voltage power supply available anywhere.
May 26, 2007 | View and View Technologies VNV AquaView...
Sony PlayStation 2 (PS2) Console Logo
149 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
