Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Pentium4 3GHZ the pc is too slow and not responding quickly and the hard disk space reduces without installing anything
    Sergeant:
  • 270 Answers
Buy a new ram.it incress your pc's perfomance
Posted on Jan 12, 2009
Pc is slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 05, 2013 | Computers & Internet
Slow processing
So Follow these steps to fix computer freezes problem::
Sep 02, 2013 | HP Computers & Internet
This laptop is very slow
Slowness in the laptop can be due to many reasons. You may upgrade your processor( to i5 or i7), but that will be too costly. Try increasing the RAM of your laptop. Also don't overflow your hard drive. Decrease in free space on your hard drive will ultimately slow down your laptop.
Aug 28, 2013 | Computers & Internet
Laptop runs very slow asus
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things -
1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM.
2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc.
3. Uninstall/remove unused programs, this will also free up hard disk space.
4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it.
5. Install latest Windows updates.
6. Update virus definition files and scan computer for viruses, Trojans, malware etc.
7. Clear the Internet cache for faster browsing.
8. Hard disk maintenance is required at least once a month to keep it functioning efficiently.
Run the following programs -
Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space.
Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
May 12, 2013 | ASUS Computers & Internet
How can i get my pc to restart without taking much time?
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 17, 2013 | Dell Computers & Internet
Hp netbook is running so very slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Jan 17, 2013 | HP Mini 1000 Netbook
Slow to respond somtimes never without removing previous requests
hello
one of several issues can cause slowness in any program or hardware
1) your HardDiskDrive capacity is peaked ( small amount of hard drive space will cause slowness in computer : you need at least 20%-25% (15-20G space to run OS and software) of HDD capacity to run your computer w/o problems
2) you may have a virus , go to www.malwarebytes.org and www.microsoft.com to download MS Security Essentials
3) run Disk defarg and Disk Cleanup
4) reinstall the Epson printer drivers if you have to , www.epson.com
hope this helps
Jan 30, 2011 | Epson Stylus Photo R300 InkJet Printer
Very slow and not responding
Clean up disk errors (Run once a week)
Whenever a program crashes, or you experience some power outage, your computer may create errors on your computer's hard disk. Over time, the errors can slow your computer. Luckily, the Windows operating system includes a Disk Check program to check and clean any errors on your computer and keep it running smoothly.
Remove temporary files (Run once a week)
Your computer can pick up and store temporary files when you're looking at Web pages and even when you're working on files in programs, such as Microsoft Word. Over time, these files will slow your computer's performance. You can use the Windows Disk Cleanup screen to rid your computer of these deadbeat files.
Rearrange your data (Run once a month)
Don't be shocked, but your computer can get sloppy. Your computer often breaks files side by side to increase the speed of access and retrieval. However, as files are updated, your computer saves these updates on the largest space available on the hard drive, often found far away from the other adjacent sectors of the file.
Make Internet Explorer run faster
The Web is a sparkling achievement of modern society. It's everywhere-from the home to the classroom. We use it to communicate, to work, to play-even to waste time when there's nothing else to do.
Automate Microsoft Update (Configure once)
Microsoft works constantly to release updates to Windows and other Microsoft products, including Office. At Microsoft Update, you can find and install all these updates-not just the critical ones. Often, these updates will improve your computer's performance.
Install antivirus and antispyware programs
Computer viruses and spyware (hidden software that gathers information about you without your knowledge or consent when you're using a computer) both reduce system performance. Computer viruses can not only reduce performance, but they can also destroy data. Any computer that accesses the Internet should have antivirus and antispyware programs installed.
Dec 28, 2010 | ASUS Computers & Internet
Laptop gets hot
An overheating problem will cause the CPU to shut down and if this is not fixed then eventually the CPU will fail. Check the fan to see if it spins freely, also check the heatsink and fan assemble to see if it is clogged with dust, if so loosen the dust and vacuum to remove the dust. If the fan does not spin, then the fan bearing has seized up and the fan needs to be replaced.
A slow computer can be caused by several things.
Insufficient RAM especially if it has 256 Mb or less. - Install more RAM
A virus scanning program is running. - It will speed up after the virus scan has completed.
Two or more applications are running at one time. - Closed unnecessary programs.
Running low on hard disk space - the swap page file space is too low. This can be increased or let Windows adjust the swap page automatically, provided there is sufficient disk space.
You need to do hard disk maintenance at least one a month, Run Disk Cleanup and defrag on the hard disk. This will free up hard disk space by removing old and temporary files that are no longer needed. Please click on this link and follow my instruction on hard disk maintenance ;-
http://www.fixya.com/support/r3559146-hard_disk_maintenance
Jul 18, 2010 | Dell Inspiron 1150 Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
