Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
The component input only shows red hue - GE D52GW12 52" Rear Projection HDTV-Ready Television
    Top Expert:
  • GE Master
  • 14,553 Answers
Saw a duplicate of this question--not likely the board in the set---suspect the unit feeding signal has a problem----try another source that is component connected with DIFFERENT cables or flip the cables around to test them----source is likely reason---cable box or?
Posted on Dec 02, 2012
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
We have used our projector for years, but are now having a problem with the picture. The picture that shows on the screen is shown in a red/purple hue. Any suggestion on how to fix?
Are you using component video inputs? You could check the green connectors on both ends of the video inputs. They sometimes develop a poor connection. I would not throw a lot of money at it. It was a good projector in its day but they sell used on ebay or craigslist for $100 - $300 now.
Hope this helps,
Feb 19, 2011 | InFocus ScreenPlay 4805 Multimedia...
Hello, My projector has approx 400 hours of run time. It will not project any hues of red. Any suggestions?
Does it show red hues without any devices connected to it? If the colors are fine without an input device, the problem is your cabling or a connection. To check these, do the following:
1) Disconnect all your cables and observe the ends to make sure they are undamaged. If they look good, reconnect them.
2) Flex the cabling, moving a few inches at a time, starting at one end and moving slowly to the other while watching the projected image. If you see any change, you have found a damaged cable and need to replace it. If nothing is found, then try step 3.
3) Replace your cables with any spares you might have. If this does not fix the problem then go to step 4.
4) Go into your projector menu and find your color settings. Try adjusting these to see if you get the red hues.
If none of the above provided a helpful solution, The problem is usually the internal color panel. The last time I had one of those repaired it cost about $2000. If you are not very experienced repairing electronics or electronic components, you should not attempt this.
Aug 30, 2010 | Hitachi CP-X260 LCD Projector
Mitsubishi wd 52525 lost greens and blues. only colors on screen are red hues.
This the classic symptom for component input wires being crossed. Check color coding on tv input and signal sourse. Green,Blue and Red wires must correspond. If ok Is the color off on the tv menu also. If so and wires are ok replace light engine.
Nov 03, 2009 | Televison & Video
My Sony Bravia's screen is showing images in red and black only. By playing with the input sockets at the back (pulling out the leads and reinserting) it was temporarily fixed the problem but, now it seems...
If you are using Component Input (green/blue/red inputs) with component patch cords, try using other input jacks ( Video In (yellow) or Cable/RF In). If the color is good, then replace your Component patch cord, the green one is broken.
Aug 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No color hues
Have you tried more than 1 source? If this only happens with 1 source- if you're using component cables (green, blue, red) then make sure there is nothing wrong with it. Another thing that can cause this, is a component (RGB) device being plugged into a composite a/v input (yellow white and red).
If this fails, or if the problem is with all sources, the TV is the problem and probably won't be easy to diagnose or repair yourself.. I'd call the manufacturer if this is the case.
Jun 21, 2009 | Philips 43P8341 43" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
