Question about Kitchen Ranges
Can I replace the broiler element myself?
The broiler came on by itself and won't go out. I received an F-2 error message which seems to mean it can only be fixed by a service repairman.
  • 1 more comment
  • Jo-Ann Allan Dec 02, 2012
    We removed the element and the wire remains "hot" - so apparently it's the electronics that need to be replaced. Is it cost-effective to do it. I'm really not interested in buying a new stove at the moment - haven't had time to research what I want, etc.
  • Jo-Ann Allan Dec 06, 2012
    The problem was the control panel but it couldn't be just replaced as the part no longer is available, so we had to send the panel out to be rebuilt.
  • Ty Roshdy Dec 06, 2012
    Unfortunately that is becomming a more common problem these days. I have had to send boards to be repaired and they work fine. They are usually cheaper that a new board. This is a plus.
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
It sounds like the control board has a stuck or welded relay. It is fairly expensive to replace the control board but not too difficult. Just make sure you touch the chassis (metal) of the stove before touching the new control board and of course have the power shut off or unplugged before attempting any repairs. You will need your make and model number along with your serial number in order to order the part.
Posted on Dec 03, 2012
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jun 02, 2011
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore Ultra
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
I am having receiving problem
I am not sure exactly if what I did solved the problem.
The main thing was I deleted messages from my in, sent, spam & finally emptied trash. But it didn't seem to have made a change yesterday.
Today I received a message from yoy (Fixya), I then tested it and it seems to be working fine.
Maybe a routine night job by Yahoo permenantly removed my deleted messages and created space.
If this is possible please let me know.
Oct 28, 2009 | Yahoo Mail
Open Questions:
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
