Arris Surfboard Gateway Sbg6580 Docsis 3.0 Wireless Cable Modem Logo
Posted on Dec 02, 2012
192.168.01 how to set up cz my internet is slow and share wifi is slow too
My Akai tv won’t connect to the internet wirelessly
wow no TV model stated, wow ! model NUMBER.
the #1 top question about computers (besides dead ) is
wifi dead, everybody uses it and it loves to fail or run slow.
wifi is a SHARED resource that you do not own. ok?
you are just user of the radio channel, shared, switch to channel 5 yet ? at the router but I digress.
The TV must be close to the router not 50feet away. ok?>
buy a AP access point wired bridge> (ask) put it near TV ?
first off use wired Ethernet, see it works and everyday forward no PAIN.
if you must use WIFI learn to test it first. ok?
learn your credentials too. first. SSID and PW.
on a PC at home try wifi now, or on any smart cell phone
turn on wifi and turn off say 3G, does wifi work now?
if yes, then wifi is OK, testing wifi done.
now back to that TV (no model stated at all,sticker on rear words)
The TV can (most smart TVs) have a reset networking feature
RTM read the manual yet, id read it to you but no TV stated.
all do really, reset it and then it goes in to wifi setup
it asks you 2 things, really, just 2,
your SSID, that is your home wifi router name used in the PC or smart phone tests above.
my TV and all PCs show like 10 homes near by there SSID
and mine, , mine is (lie) FIDO123. so on my TV I see FIDO123.
and click that, now it asks for my password passphase,
mine is written down and is COMPLEX. (security max here)
I type that and like magic the wifi works , if not is it to far from your router , is it? TV >>>>>router???? distance is what? walls? of concrete are bad. for wifi. (dense walls bad of any kind)
Wifi is problematic for sure 801 b or g and n (geT "AC" if TV allows this) The best TVs are set up for. 801.11-/ac" features.
https://en.wikipedia.org/wiki/IEEE_802.11ac
Wifi can run slow, or 1/2 speed if one other errant device in home causes N bonding drop out, making TV show buffering delays.
http://www.pcdied.com/DevMan/internet.html#wifi
here is LG TV that does "AC"wifi spec.
  • LG 55" Class 4K (2160P) Ultra HD Smart LED HDR TV 55UK6090PUA I your router is "AC"rated the pair work very good.
    TVs 2013 and newer have this now for 6 years.
    Can u get Free WIFI anywhere
    if its expensive and you have a decent neighbor or two who has wifi internet service you could let your wifi search for networks and find one or two that indicate a strong signal and ask your neighbor if they would provide the passcode to you and share their connection for half of what they are paying, or offer to cut their grass or something ! Good luck
    I have emachines e525,the wifi works fine at home but when i use it at the public library it get slow
    That sounds normal as public wifi networks are often busy and have lots of users to allow/share access to the internet
    I have a laptop OS win7. I hav internet over LAN port. My laptop has wifi. How can i share my internet with laptop wifi. i hav a mobile which has wifi. My question is how can i share my internet through...
    You can use your laptop to share the connection to your mobile through wifi. You need to have wireless router to share the connection to your mobile through wifi.
    It sounds to me like you only have a cable/adsl modem bringing in your internet connection. To share your internet with other wifi devices you will need to buy a Wireless router. Be aware you can buy adsl and cable routers depending on what your broadband provider has given you. Take these details into a computer shop who will advise you of the right type of router to buy. Dont buy cheap, go for something like a netgear router.
    How to make vista act as router? without using any outside router !! the inbuilt wifi syatem should act as router..
    Yes well IF you use two network cards, a WiFi Adapter & an Ethernet Adapter, you can do this, now with a WiFi adapter, as you say, What you do is connect to the internet on the PC, and "Share" the internet connection via the WiFi. You set up the WiFi as either an "Access Point" or a an "Ad Hoc" network, if you want to communicate with the "Other" PC's, and have then communicate with you, as well as access the Internet. So setup is simple, using the manufacturers DVD install the WiFi. card, then, Set it up as you wish, the PC's that connect should be in the same Workgroup, have sharing enabled and be passworded too then as said connect to the Internet and the "Other" pc's will be able to "Burrow" out through you Internet, through the ADSL Modem attached to the "Main" PC. Usually via the Ethernet port. You still need to set up an SSID and use a WAP/WEP key for security. on the WiFi card.
    10helpful
    2answers
    Can't use WiFi on Aino
    Guys i foun a solution for the problem.
    Just enable content sharing and in the connection setting window in the browser set allow local connection, and then it will use the wi-fi . cheers
    Top Arris Lands Phones Experts
    k24674
    Are you an Arris Lands Phone Expert? Answer questions, earn points and help others
