Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
192.168.01 how to set up and get fix, got slow internet and wifi slow too.
Slow iPad?
You can start off by reseting your network setting. You will need to reconnect to wifi with your wifi password after.
Go to settings
General
reset
rest network settings
also would be a good idea to power cycle your router. hope this helps
Mar 19, 2017 | Apple iPad Tablets & eReaders
IPhone 3G is slow, videos won't load
please lg gb 230 securite coad breck
Jan 17, 2014 | Apple iPhone 3G
I can't connect my ipod to the internet
If you're having trouble with your wifi connection,try to follow this steps.
* iPod Touch shows no WiFi address (Tap Settings > General > About and scroll down to WiFi Address.
* iPod touch appears to be connected to a WiFi network but cannot use Wi-Fi for checking email and surfing the Internet.
* iPod Touch WiFi icon is showing as grayed out.
* When you tap Settings > WiFi and then you see no network entries.
If you have wireless problems,here is another method to do.
First you need to back up your data by syncing your iPod touch to iTunes. It is very important you do this before proceeding with the fixes below.
1. On the iPod Touch go to Settings > General > Reset and then select Reset Network Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 2 below.
2. On the iPod Touch go to Settings > General > Reset and then select Erase All Content and Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 3 below.
3. If the above fixes don't work then the only thing left is to restore the iPod touch software using iTunes which will erase all data on the device. So before restoring make sure you back up your data by syncing with iTunes.
After the restore is complete, you can resync with iTunes to load the data back to your iPod Touch. Now see if your device shows a WiFi address (tap Settings > General > About and scroll down to WiFi Address). If none of the above settings and fixes work ,then you might want to consider getting your iPod touch repaired by Apple.
Jul 20, 2011 | Apple iPhone Smartphone
THERE IS ALWAYS SLOW CONNECTION
If you are running more than one computer at a time on the internet, and are also connecting one or more through WiFi, then yes, the connections will be slow. You may need to upgrade your connection (memory, MB) with your service provider.
Here are some things to try if you are only running one comp and the connection is slow:
1. Restart the computer (shut off the router); as the computer is re-loading the O.S. turn on the router (if there is no on/off button, simply unplug and plug back in during this process).
2. Wait until all "start up" programs are finished loading, wait until you see the connection in the bottom right of your screen (if WiFi, or if set up to be displayed in that area).
3. Go into the Internet Options under Control Panel, and make sure you have enabled "pop-up" blocker (also in the File Menu, IE)
Let me know if you need further assistance,
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 07, 2011 | 2001 Saturn SC
My internet connection via the router (d-link DI-524) have slowed down. how do i reset settings or put a password?
Maybe you have an open WiFi (no password wireless) and anyboby near can connect to your router and download files, this can slow down your Internet connection. To put a password to your wireless network, enter setup preferably by a wired connection to router, in your browser type the default IP address of it (http://192.168.0.1), the user is admin and its password must be left blank (default settings), at the Home tab go directly to Wireless option since you'll only change your WiFi from unsecure to secure, there you can choose the security type, WPA is recommended, after select it you can put the new Key (password) of your WiFi, and finally apply to get changes working, just remember that after this procedure, you'll have to enter the password in each new wireless connection to your router.
Feb 21, 2011 | D-Link AirPlus DI-524 Wireless Router
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now....
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Nov 03, 2009 | Acer Aspireā„¢ T180 PC Desktop
ARCHOS 605 30MB SLOW INTERNET SPEED and OPERA BROWSER CRASHING: Speed tests from Speakeasy.net show download speed less than 300Kb/s and up load speed is 127Kb/s, while an adjacent wireless laptop...
How do I get internet away from my house on my archos 605 wifi, I can get it on my BTHUB in the house, is there a list of HUB I can conect to. when I try to conect a list comes up but they are all locked
Nov 11, 2008 | Audio Players & Recorders
Internet connection
downloding speed is slow.i cant download any file
Sep 30, 2008 | HTC S710 Smartphone
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
308 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
