Eziset 550 Drains as it fills
I have an Eziset 550 from Simpson that Drains out as it fills, so the water level never gets high enough to begin a wash cycle.
    Sergeant:
  • 198 Answers
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Posted on Dec 02, 2012
  • Heidi Newberry Dec 02, 2012
    hope this helps
SOURCE: My simpson easyset 550 washing machine keeps
my simpson 550 wint spin, its stuck with a tub full of water and wont drain it. what should i do?
Posted on Apr 08, 2010
  • 3 Answers
SOURCE: My simpson eziset 550 washing machine just stopped
hope this helps
Posted on Feb 25, 2010
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
SOURCE: I have a Simpson Eziset 550 washing machine and it
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Posted on Dec 18, 2010
SOURCE: I have a Simpson eziset
i have the same problem. did you end up fixing it or find out whats wring with it? thanks.
Posted on Jan 09, 2011
Hello, hope you can help, I have a eziset 550 simpson when I put the water on it starts filling but won't stop I have to listen & try to change settings so the water that won't stop running doesn't...
there is a small hose from the bottom of the tub to the water level switch
that gets air pressure to activate a switch when the level selected overcomes the switch spring
At that point the water solenoid is turned off and the wash cycle begins
over flowing indicates that the level sensor is not working or the inlet solenoid and diaphragm is faulty
if it doesn't progress the wash cycle , that indicates a program board problem so call the technician for a proper diagnosis
Sep 13, 2017 | Simpson Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a simpson eziset 550 5.5kg washer when filling at the start of the cycle it over fills and floods is it a timer or water level sensor problem?
I had this same issue with my Eziset 500 and fixed it myself. Behind the level switch there was a vacuum pipe that went along the back of the washing machine (rear cover removed to gain access) that went to the water level sensor. I had found the vacuum hose had rubbed through causing a vacuum leak. I simply masking taped it up as i was too lazy to walk into my garage and get a new hose and hasn't had an issue since (fingers crossed). I will eventually get around to repairing it properly one day though :)
Jan 26, 2012 | Washing Machines
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Hi, my Simpson eziset 605 doesn't hold any water. It fills and drains straight out then flashes and beeps HC on the display. Any ideas why?
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Apr 19, 2010 | Washing Machines
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
Washing Machines Logo
489 people viewed this question
Top Washing Machines Experts
