Question about Lands Phones
Code for systems - Lands Phones
    Master:
  • Lands Phones Master
  • 368 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 02, 2012
Panasonic home theather does not read DVD and display a U703 code
Panasonic display motor Home Theater Systems Questions ...
www.fixya.com > Forum > Tags > display motor > Home Theater Systems
Panasonic home theater systems display motor related questions and answers. Ask your ... ...getting a DVD H02 code it wont play cd's or dvd it will display the code and say stop. Is this fixable or should ... ...display a U703 code. Does I need to ...
Panasonic euromax new codes Home Theater Systems ...
www.fixya.com > ... > euromax new codes > Home Theater Systems
My Panasonic home theather does not read DVD and display a U703 code. Does I need to bring the equipment to a repair center or is better to get a new one?
Panasonic Home Theater System System Dvd u703 ... - Fixya
Dec 17, 2015 | Panasonic Sa-ht740 5.1 Channel Home...
ENG. LIGHT ON CODES PO 442 ANDPO 445 IS SHOWING UP ON SCANER
The PO 442 code is an EVAP system small leak, either in the evaporative system or cooling. Sometimes this will occur after a drenching rain and remain until the diagnosis code is reset, usually will disappear after you read the codes. If not, a dealer can reset the code system via the radio believe it or not. PO 445 is similar, an EVAP system code but is usually related to gas vapors being sent to the engine rather than through the atmospheric venting system. Check the gas cap system here first, a gas cap not properly tightened (3 click) will sometimes cause this. Also, look to the spark system wiring harness or purge control solenoid.
Sep 16, 2014 | 2001 Dodge Ram 1500 Truck 2WD
4 Codes in computer
code p0128 indicates a mechanical fault ( could be the thermostat stuck open)
code p0174 -system too lean -bank2 ===causes --intake /exhaust leak--fuel pressure/pump--injectors--AIR system--hose connection/s
code po171 refers to system too lean bank 1 same as po174 with the HO2S sensor being the culprit. As to all being related . only by way of the o2 sensors
code p0442 is not connected to the first 3 as it is in a different section of the fuel system
Apr 09, 2014 | 2003 Saturn VUE
Radio code
OBD system tests
Possible fault codes:
P1000 OBD system tests Operation not
completed
Setting of the fault code P1000 has no
influence on the system <Engine
management>, smooth running or performance
as long as it is automatically erased
whilst driving.
The fault code P1000 indicates noncompletion
of system tests.
* Misfire detection
* Evaporative emission control system
* Exhaust-gas recirculation
* Lambda sensor
* Exhaust gas catalytic converter
The fault code P1000 cannot be erased. It
is cancelled automatically once the
vehicle has completed certain driving
cycles.
Jul 27, 2013 | 2007 Ford F
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
Toyota 4runner 1994 engine codes 12,52,71 what are these
Code 12 Engine revolution signal missing
Code 52 Knock sensor fault
Code 71 EGR system malfunction
May 04, 2011 | Toyota 4Runner Cars & Trucks
Error code 400
If it is system error code.
System error code 400 means "The thread is already in background processing mode." This error code may also display as "ERROR_THREAD_MODE_ALREADY_BACKGROUND" or as the value 0x190.
Try this,
Clean your system using any commercial or free system utilities like CCleaner(free), and cleanup the system registry too.
Jul 08, 2010 | Microsoft Windows XP Home Edition
Howdo i enter diagnostic mode 1994 deville
TROUBLE CODE DISPLAY:
After entering On-Board Diagnostics, a segment check is automatically performed and then any trouble code stored in computer memory will be displayed. Codes may be stored for the Powertrain Control Module (PCM), Instrument Panel Cluster (IPC), Air Conditioning Programmer (ACP), Supplemental Inflatable Restraint (SIR), Traction Control System (TCS) or Road Sensing Suspension (RSS) systems.
Each trouble code consists of the system abbreviation: (E: Engine, PCM), (I: IPC), (A: ACP), (R: SIR), (T: TCS), (S: RSS), a three digit code identifier, and the letter C or H. All codes for each system are displayed together, in the order of their three digit number (lowest first). The final digit of the code, a "C" or "H" is used to indicate whether the code is Current or History. A "C" means the fault was still present the last time the diagnostic test was run, while "H" means the failure was not present the last time the code was tested for.
If no codes are present for a system, a "NO X CODE" message (with "X" being the system i.e. E, I, A, R, T or S) will be displayed. If the communication line to a component is not operating, a "NO X DATA" message will be displayed, indicating that the IPC could not communicate with that system.
SELECTING THE SYSTEM:
After trouble codes have been displayed, a specific vehicle system PCM, IPC, ACP, SIR, TCS, RSS may be selected for testing.
The first available system will be automatically displayed (i.e. PCM?). While selecting the system to test, any of the following actions may be taken:
  1. Depressing the "HI" button on the CCC will select the displayed system for testing.
  2. Depressing the "LO" button on the CCC will display the next available system selection. This allows the display to be stepped through all system choices. This list of systems can be repeated following the end of the system list.
  3. Depressing the "OFF" button the CCC will stop the system selection process and return the display to the beginning of the trouble code sequence.
SELECTING THE TEST TYPE:
Having selected a system, the first available test type will be displayed (i.e. PCM DATA?, PCM CLEAR CODES?). While selecting a specific test type, any of the following actions may be taken:
  1. Depressing the "HI" button on the CCC will select the displayed test type. At this point the first of several specific tests will appear.
  2. Depressing the "LO" button on the CCC will display the next available test type for the selected system. This allows the display to be stepped through all available test type choices. This list of test types can be repeated following the display of the last test type.
  3. Depressing the "OFF" button on the CCC will stop the test type selection process and return the display to the next available system selection.
CLEAR CODES
Selection of "CLEAR CODES?" test will result in the message "CODES CLEARED" being displayed along with the selected systems name. This message will appear for 3 seconds and then return to the next available test type.
EXITING DIAGNOSTIC MODE:
To get out of the diagnostic mode anytime during the test, depress the "AUTO" or "DEFOG" button, or turn the ignition switch "OFF." Trouble codes are not erased if this is done prior to selecting "CODES CLEARED."
ECC Trouble Code Descriptions:
  • DTC A010 - Outside Temperature Sensor Circuit
  • DTC A011 - High Side Temperature Sensor Circuit
  • DTC A012 - Low Side Temperature Sensor Circuit
  • DTC A013 - In-Car Temperature Sensor Circuit
  • DTC A015 - Sunload Sensor Circuit
  • DTC A037 - Loss of IPC Data
  • DTC A040 - Air Mix Valve (Door) Circuit Problem
  • DTC A047 - Low Refrigerant Charge
  • DTC A048 - Low Refrigerant Pressure
  • DTC A050 - HVAC - Coolant Temperature Too High
Jan 28, 2010 | 1994 Cadillac DeVille
For the code snippet output of this if code produce if aNumber 3
There is a bug in this code. The correct code is:-
if (aNumber >= 0)
if (aNumber == 0)
System.out.println(''first string'');
else
System.out.println(''second string'');
else
System.out.println(''third string'');
Mar 21, 2009 | Computers & Internet
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
