Question about Bose 901 VI Main / Stereo Speaker
Denon 3600 osd
I cant seem to get or find the on screen display,I have manul but still cant get it what im trying to do is add a sub and cant get in unit to turn it on
    Brigadier General:
  • 8,546 Answers
So I presume you haven't done ANY setup as the OSD is necessary for all of it.
Somwehere in the manual it probably says to run a single RCA video connection from MONITOR to a suitable Video input on the TV. How your TV works is anyone's guess. Select the appropriate input.
The manual probably discusses SETUP and how to initiate it.
Posted on Apr 13, 2009
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
I am unable to get my TV to display the Denon setup menu. I tried calling Denon, and we then verified all my connections. Still no luck. WTFO?
The most basic On Screen Display:
You run a single RCA-type cable from Monitor Out to any available Video Input on the TV and select that input at the TV.
Feb 10, 2011 | Denon AVR-3600
Hello, I have an denon avr-3801 and have the same problem that my set up will not pop up on the display screen. one expert on here said it can be disabled on the remote, and to enable it. How do you do...
The setting on Page 26 says it only turns OSD off for messages other than the Menu Screens. If you could turn the menus off how would you ever turn them back on?
If you are using only component video, see page 10, 3rd bullet.
"The AVR-3801’s on-screen display signals are not output from the color difference (component) video output jacks (MONITOR OUT)."
It needs an s-video or composite path for the OSD.
Jun 08, 2010 | Denon AVR-3801 Receiver
Just want to know whether there is a way to get a tape to auto reverse on the dual tape deck, and, what is the "OSD" button on the receiver for? This is an old Denon D-1250 shelf system. Thanks,
OSD = On Screen Display
Auto Reverse is a built-in feature of any tape deck. It would have a button that looks like > for forward and < for reverse; and probably a switch that sets the mode for automatic or manual reversal at end of tape.
Feb 24, 2010 | Audio Players & Recorders
I have a Denon AVR2801/981 and cannot get to the on screen set up using the remote. I need to assign the optical audio input for my blu ray player. Is it a problem with the remote or is it with my...
On-screen display (OSD) isn't coming up because you're only viewing picture from your Blu-Ray player. You need to switch TV input over to your receiver to get the OSD. But you probably figured that out by now. Don't worry, I've done that before too.
Dec 06, 2009 | Denon AVR-981 Receiver
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Nov 18, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Avr5800 with no on screen display
With some receivers, the on-screen display is limited to a specific video output from the receiver to your TV.
I'm not 100% positive if that's the issue with yours, but it's likely.
If you're connected via Component or HDMI out, you may want to try S-video or composite video.
If that doesn't work, consult Denon to find out which output does your OSD.
Mar 24, 2009 | Denon AVR-5800 Receiver
Denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Denon AVR-3801 Receiver
If you have checked thru the owners manual and could not find anything helpful for getting the OSD working again, you may want to try this reset procedure at the end of this post and then try to get the OSD working again. The owners manual should give instructions on how to activate the OSD.
This reset procedure will clear all the setting you have made, so make sure you know how to put those settings back in again before doing this.
If you do see the video from what ever video device you have connected to the unit (DVD player ect. ) but you don't see the OSD when you enter into any setup menu, then this reset procedure may help fix that problem.
If you are not seeing any video from the video device connected to the unit, then you may just have the wrong setting for the output from the video out to the TV. These Denon's are very complicated receivers (which you must know, since you own this receiver), and an improper setting can be causing the problems you have.
Befor eyou do this, go thru the settings menu and look for a OSD setting and see if it is turned off. If so, turn it on. If you can not find anything for the OSD try using the set up on the display of the Denon instead of the remote.
Here is the reset procedure:
With the unit turned off, hold down these two buttons at the same time:
Pure direct + Direct
while holding those buttons down, then press the power button to turn on the unit. Keep holding those buttons down for at least 3 seconds after turing the unit on and the display should flash at about 1 second intervals. then you can let off the two buttons and the unit is reset back to the same settings as when it was new. You now will need to put all of your custom settings back in to the way you need them.
Jul 09, 2008 | Denon AVR-3805 Receiver
Bose 901 VI Main / Stereo Speaker Logo
131 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
