Question about Ovens
Broken Switch HI, the top oven/grill rotary selector switch is faulty, I have to giggle the switch to make the contact. I am having trouble getting the cover/top panel (the part all the switches are on) off the top to get to the switches, can anyone advise how to remove this? Thanks
  • 1 more comment
  • rogbrimb Jan 11, 2009
    sorry that should have read jiggle...ha ha
    It's a Smeg D04SS built in (sorry thought I had put this info in title). There are 4 rotary sitches on the top panel and about 5 push buttons. I remove all these and take out 2 screws that go upwards into the panel. However, it seems there are 2 screws that go into the panel near the top from either side but I can't get to them as they're covered by the steel outer part that goes all around the top and bottom oven. To get this outer part off I think I will have to take the doors off both ovens??
  • Barry Coates
    Barry Coates May 11, 2010
    Is it freestading, or built in, and what is the make and model please?
  • Ovens Master
  • 3,463 Answers
You will have to remove the oven from the housing to gain access to the other screws that are holding the top console cover in place.
It should not be neccessery to remove the doors.
Once it is out of the unit you should be able to see any remaining screws that are fixing the console panel.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
I have a Neff B1432 built in oven and grill. About a week ago the oven stopped working properly, it won't heat up. The grill works fine. Help! thanks.
It can be 1 of 3 things .. 1 burnt of termination to element ( most common ) 2 faulty selector switch ie rotary or digital switch or 3 faulty element .... Requires technician !!
Feb 28, 2011 | Ovens
I have an electrolux oven eocl633w. The grill works with the top element but when you select oven, the lights go on, the fan goes but no heat from either element. We thought it might be the automatic timer...
It definitely sounds like the muli-function selector switch. It is probably best to contact the spare parts section of electrolux or the company which owns electrolux and quote the oven model number. You can't always get exactly the same switches as they sometimes discontinue the original.
Feb 14, 2011 | Electrolux Ovens
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Creda cooker grill not working,elements replaced, still not working. any suggestions?
Could possibly be grill selector switch faulty, or, depending on the model, it is sometimes caused by a faulty main oven door switch.
Please rate my solution.
Thanks.
Jul 29, 2009 | Ovens
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
The grill is nt working
Highly unlikely, either element gone or selector switch faulty, you need to test element with a meter.
Plz leave feedback.
Dec 13, 2008 | Stoves Premier 600EMa Electric Single Oven
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
