Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Replace Kenmore Vacuum Hose
Ref: Sears Kenmore Wispertone Vacuum mdl. 116.27612690 I purchased a replacement hose for one that is crushed. How do I remove the old one from the swivel assembly and the handle assembly on the other end of the hose? I tried to unscrew them but they appear to be glued or something. Is there a trick to removing these?
  • 4 more comments
  • Freedomrocks Dec 05, 2007
    same problem
  • laleandra Jul 10, 2008
    I am trying to find a replacement hose for a very old Kenmore cannister. Sears has discontinued the hose replacement. Can I buy just a hose part and if so where and then somehow remove the old hose and replace it with the new one? How do I get it out and how do I put the new hose in?
    Thanks
    Sears has discontinued the hose for my Kenmore Vacuum # 1162845080. Can I buy a hose somewhere (?) and then remove the old one from it's parts and replace it? How?
    Thanks!
  • mdp2 Sep 01, 2008
    I have the same problem - I was able to disconnect the hose from the swivel base, but cannot snap the new locking collar back on the new base
  • gehmandeane4 Nov 15, 2008
    I also can't replace this part.  Does anyone know how to  find a how to manuel?
  • gehmandeane4 May 11, 2010
    Does any one have an answer?  June
Check out this solution http://www.howtomendit.com/answers.php?id=25754
Posted on Feb 03, 2008
  • zonernovi Feb 03, 2008
    let me add this caution to the link previous....maybe it's my bonehead way of looking at it but let me clarify a little as I tried to detach it from the where the two hard plastic pieces meet. the tabs are under the hard plastic where the hose fits in. they slide over the ribs in the hose. they are hard plastic tabs that press the hose over a hard plastic inner pipe that the hose slides over. hope that helps...excuse I am going to glue my tabs back on now
I have a kenmore built in vacume model 116.4053280 and the
25 ft power hose keeps coming apart at both ends.I keep putting duct tape around ends.the hose is discontinued is there any other place i can get a replacement hose.
                                       John L
Posted on Oct 18, 2007
  • bakrantz Sep 21, 2010
    Order parts online using your model # to find the right items:http://www.searspartsdirect.com/
Vacuum won't shut off. Switch appears good. Won't shut off with hose removed.
The "vacuum won't shut off" problem is caused by a faulty triac (electronic component) on the P.C.B. assembly. You have two choices, depending on your handiness:
  1. Easiest: Replace the PCB: P.N.=KC86WBZRZ000
  2. More difficult: Replace the triac: P.N.=BTA16-600CW (ST Microelectronics): http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002265.pdf
The PCB costs about $25.00 from Sears, whereas the triac costs about $1.50. Sears will not sell the triac - you'll have to find an electronics parts supplier.
Feb 17, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Dec 11, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
I need a hose for a Kenmore vacuum. The serial number I found is D80501276 and model numder is 116. Another number on the bottom is 2841080. Where can I get these? Claire Salter
Go to the Sears appliance center. They should have parts for vacuums at least up to 10 years old.
Sometimes vacuum cleaner repair shops have hoses that are used that may work. Check in your community.
Mar 04, 2009 | Vacuums
I have a Kenmore Wispertone 300 cannister and I am trying to access the motor. There are four screws shown in the parts diagram. I need to remove the plastic on/off pedal to acess two screws. How do I...
I just encountered the same problem on a Whispertone 116 last evening. If it is the construction same as mine, there are four flexible plastic retainers molded into the top cover in the gap between the pedal and the motor cover. These are on the hinged side of the pedal. All four retainers must be bent in toward the interior of the vacuum simultaneously to release the pedal. A screwdriver does not work very well for this. What worked for me were four metal bars about 3/8" wide X 1/8" thick X 1-1/2" long. The pieces I used were actually the snap-off ends of some hanging file rails I found in my basement. Insert the four bars at the four retainers. They should fit snugly as they must push the retainers past the hinged portion of the pedal. To remove the pedal, rotate the pedal up in the same direction as the spring is pushing and it should come free from the motor compartment cover at which point you can access the other two screws. I suspect Sears has a special tool with four tabs to perform this trick in the repair center. Good luck!
Jan 03, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Need to know if a replacement part can be purchased and where
Kenmore canisters are privately labeled Panasonic canisters and sometimes panasonic parts will fit them. Any reputable independent dealer should be able to tell you if the part you're looking for is intercharngable with a Panasonic, but he/she will probably need to actually see the unit.
Your other option is to take it to the Sears service dept. They are the only ones who have access to the schematics and "Kenmore" parts. It'll probably be more expensive through them though.
Dec 02, 2008 | Kenmore 22812 Bagged Canister Vacuum
I require the Old hose handle/end plug disassemble instruction for a Kenmore Whispertone model 116.20600001c
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=575171
Generic problem for all Vacuums
Posted by hrabed on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are some hoses that have separate hose ends and some hoses that you have to replace the entire hose the way the manufacturer made the hose. There are some local vac dealers that may have a new, or a good used hose or they also may have a non-genuine replacement hose that you could use. It really depends on the hose that you have and how it was made.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Will not start
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109422&thid=505790
Will not start
Posted by jlouis on Apr 11, 2008
Works sometime. Thought it was old HEPA filter. Replaced it and it ran for a few minutes and stopped again.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22612 Bagged Canister Vacuum. It sound sot be that it could be your electrical hose be have a short in it or your carbon brushes needs cleaning or replacement or the worst problem is that it could be your motor, fields or armature. Most motors can be rebuilt but I would check the simpler things 1st B4 you try to rebuilt or replace the motor.
I am not sure if Sears / Kenmore can download the owner’s manual from the website but I would suggest that you call the Sears / Kenmore Factory to have them send out a copy of the owners manual so that you can do it yourself or if that is not the way you want to do it contact your local vac dealer and they can help or call the factory for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 11, 2008 | Kenmore 22612 Bagged Canister Vacuum
Kenmore canister hose
The part number for the hose is 4370993, you can go to sears.com, put int he part number and order it. You will only get just the hose, you have to take the ends off of the old one and put them on the new hose.
Mar 11, 2008 | Kenmore 22822 Canister Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
5,199 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
