Question about HP PSC 1610 All-In-One InkJet Printer
Only copies solid black ,but prints ok from the computer
Does not copy
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
I am unable to copy light or very light color in my Canon ir 2870.Gradation of shed are not available.How can I fix it.
Check OPC drum and charging roller.
Go to service mode and set develop
asterisk * button then press at a time 2 and 8 again press asterisk * button
select copier>adjust>develop
touch on develop increase the develop value 10, 20 as your satisfaction..
Jun 28, 2016 | Canon Office Equipment & Supplies
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
How to get the black darker
You can use Paint on your computer to modify it. If not it just might be the type of printer. See if you can buy darker ink at another store. If not your pretty much stuck like that. You can also go to copy stores or most major stores to get stuff copied for free or cost....
Windows 7 XP Security Center
Jan 29, 2014 | HP Designjet 5500 InkJet Printer
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Blank copy
please check corona wire may be it was broken re-wear it then print ok
Nov 21, 2009 | Kyocera CS-2550 Black and White Copier
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
Copying with 4" solid black vertical stripe
what about if you print from computer or do an internal print like a self test? if print looks good on those, you most likely have a scanner problem, which is the mechanism under the glass.
razors
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
