Question about Carrier Bryant Fan Blower Control Board HK61EA005
Does anyone have the scamatics on carrier control board HK61EA006
FAN NOT BLOWING ON INSIDE UNIT, CARRIER FX4CN042T00AAAA LAST TIME IT WAS SOMETHING ON A CONTROL BOAQRD THAT HAD A RED LIGHT ON IT, QUESTION WHERE IS THAT LOCATED?
If your outdoor unit has a control board/circuit board, it will located at the outdoor units electrical panel where the line voltage electrical whip goes into the unit. Should be 2 screws that hold the panel/cover on. Turn off power, remove panel, and board should be visible.
Mar 30, 2017 | Carrier Heating & Cooling
Carrier hh84aa017 wire scamatic
If there are relays on a board it is not a part you can order separately
Jun 13, 2013 | Carrier Heating & Cooling
Usb charging port fell off inside my Aliph Jawbone Jambox Blue Wave Wireless , opened it up and have to find battary cause circit board broke off with port! wtf the usb port is always coming off stuff
A Jambox is a wireless speaker, not a phone. Anyone claiming to know the answer while referring to phones clearly doesn't know what they're talking about.
The question is mis-filed under cellphones, but the respondents so far don't seem to care that it's not a phone at all. :D
Take a look here: https://www.youtube.com/watch?v=X5APtwqtEps
Apparently this is a very common problem with the Jambox, so contact support first and ask them to replace it.
Mar 03, 2013 | Cell Phones
Control board grounds out
Does the 5 amp fuse on the board keep blowing?
Dec 02, 2012 | Carrier Bryant Control Board Air Handler...
Carrier ac light on board out
High voltage goes to board then to transformer. 24v comes out transformer into board. Check high voltage going to transformer if have votage but no low voltage out other side 24v then transformer is bad.
Aug 28, 2012 | Carrier Heating & Cooling
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Carrier Bryant Fan Blower Control Board HK61EA005 Logo
35 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
