Panasonic dmr-ez27 I just hooked it up to my 32"
    Sergeant:
  • 198 Answers
TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs
Posted on Dec 02, 2012
SOURCE: No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Posted on Jan 08, 2008
SOURCE: Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Posted on Jul 30, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Posted on Sep 30, 2009
SOURCE: PANASONIC DMR-EX768 DISPLAYS MESSAGE EXT-L
Hopefully you will have figured this out by now but you have accidentally turned on the external link function (used to automatically record from a sky box or similar) - simply press the ext-l button on the remote (second row from the bottom of the remote, 3rd button from left) to turn it off again and everything will work normally once more.
Posted on Apr 14, 2010
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
How to play region 1 dvd's on dmr-ez27
http://service.us.panasonic.com/OPERMANPDF/DMREZ27-MUL.pdf
this plays region 1 or all regions disc.....recording format can be different, may not play some discs...read this.......good success, meder's tv service
Nov 28, 2012 | Panasonic DMREZ27 DVD Recorder
What cables do you need to connect a dvd player to a vizio hdtv
If your dvd player has a hdmi hook up "easy" just use 1 hdmi cable from the dvd player to the tv. If not use the 5 cord for better picture quality.
Nov 08, 2009 | Vizio L32 32 in. LCD HDTV
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Panasonic DMR EZ27 displays 'Guide' and freezes
There's a newer firmware version (1.13), that's available from Panasonic rather than by download. Check out this forum thread
Jan 02, 2009 | Panasonic DMR-EZ27K
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
Need new manual
Hi - You can download the manual from the link underlined in blue below:
DMR-ez27
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
DMR-EZ27, DMR-EZ47, DMR-EX77, DMR-EX87
This is scheduled to be broadcast on 6-2-08.
http://www.dtg.org.uk/retailer/download_schedule.pl user_offline.gif
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
