Question about Haier Refrigerators
I have a Haier AES44VS mini refrigerator that won't get cold.
Compressor gets hot, and I can hear a clicking in the relay.
SOURCE: My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Jun 15, 2011
  • 409 Answers
SOURCE: clicking near compressor but doesnt
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Posted on Sep 13, 2008
erpaalai
  • 999 Answers
SOURCE: Mini Fridge not working MCBR445
Compressor is in a locked up/ no start condition. the overload cools enough to reset and tries to start it again and kicks out on amp draw, then the whole cycle starts over again.
Eric
Posted on Jul 16, 2009
SOURCE: Refrigerator not cooling, do not hear compressor
clicking sound is motor protector cuting out compressor drawing to much current replace compressor.
Posted on Oct 21, 2009
SOURCE: refrigerator will not get cold.
the freezer and the fridge not cooling
Posted on Jul 06, 2011
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Refrigerator isn't getting cold anymore
Check if the compressor is running. If not, test for power to the compressor. If the compressor feels very hot, and you hear something clicking, then you probably need a new starting relay which is inside a little box on the side of the compressor. You might have to wait several minutes for the compressor to cool off before it will do its next "click-on" and "click-off" thing. If the compressor is cool, and there is power going to the relay, the overload (next to the relay) could be "open" (no continuity).
Sep 07, 2011 | Beverage-Air CT96Y1B (6.8 cu. ft.)...
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Clicking noise not cold
heatman101
Aug 07, 2011 | Haier Refrigerators
Anyone know where to get a relay for a hsa04wncbb. Haier 3.9-4.0 mini fridge? I believe its the relay, the main power comes to it and gets redistributed to the compressor and stuff. Any help would be...
Here are all the parts listed for that refrigerator, Click Here=>
HSA04WNCBB HAIER 1.8CU. MINI REFRIGERATOR
By clicking on the part numbers in blue on the left should take you to where you may find those parts. If you have any questions please let me know, Thanks, Sea Breeze
If helpful please rate this solution...Thanks Again
Jul 24, 2011 | Haier Refrigerators
Condenser coil gets very hot
heatman101
Mar 16, 2011 | Haier Refrigerators
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
Light is on and thats it
Check to see if the compressor is hot. be carefull it can get really hot if its malfunctioning. If it is not hot then maybe the breaker switch on it does'nt reset anymore. Try replacing that.
Jun 28, 2009 | Haier HSL04WNBSS Compact Refrigerator
Refrigerators Logo
76 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
