Question about Sewing Machines
Where can I purchase a needle plate
As far as I can tell the plate is broken and that should fix the problem
  • Sewing Machines Master
  • 1,564 Answers
Google search "needle plate for "make and model of sewing machine"
Posted on Dec 02, 2012
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
  • 537 Answers
SOURCE: needle plate ?
Check this link:
http://www.google.com/products?hl=en&q=ULT%202002D%20needle%20plate&um=1&ie=UTF-8&sa=N&tab=wf
Posted on Feb 26, 2009
  • 25 Answers
SOURCE: how do I centre the needle in the base plate it
I think you may have put the timing out. You will have to take it to a machine shop
Posted on Feb 11, 2010
  • 13 Answers
SOURCE: THe needle hits the base plate
sounds like a bent needle. did you try changing it to a new one? I have gotten bent needles new in package before so try a couple out...hope it helps
Posted on May 14, 2010
  • 1788 Answers
SOURCE: I have a Singer 5430c and the needle plate is
They can be bought for around $28 online. Or else call Singer at 1-800-4singer and order from them
Posted on Feb 21, 2011
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
When trying to put the needle in the far left position an error or fix it pops up
I think the needle mechanism is out of adjustment. In the center position, is the needle centered over the hole in the needle plate (check with a plate that has the single hole for straight stiching, not the slotted hole for zig-zag sewing). Take it to a professional for a tune up.
Mar 19, 2014 | Husqvarna Designer I
Broken feeder plate
It would be called a Needle plate or Throat plate. Good luck finding them, I've never seen anything in the domestic machines... and industrial machines are just as difficult to find. Check with whomever you purchased it from. Perhaps they can direct you to a parts place.
Nov 29, 2012 | Yamata FY700 Mechanical Sewing Machine
Replacement parts
try
sewingpartsonline.com
premiersewing.com
sewusa.com
Apr 06, 2012 | New Home HF-504D Mechanical Sewing Machine
My needle broke. How do I fix it?
hi! there, first you have to raise needle bar to its highest position by turning the handwheel toward you.hold the broken needle itmay drop after loosen broken needle.,loosen the needle clamp screw using by a srcewdriver pull out broken needle.take new needle holding the needle with the flat side away from you.slip the needle into the needle bar groove.make certain it is up as far as it can go tigthen the needle clamp screw with a screwdriver,aas shown1b71a34.jpgregards
Mar 28, 2009 | Euro-Pro Shark 60 - 384
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
No matter how small or large my needle is, it breaks frequently. It is as if it does not always move straight up and down because it slams into the "plate" which is now all rough. I purchased my machine...
Seems as though the needle bar may be bent check this by turning the machine by hand, without a needle, if there are tight spots, then the bar may be bent. Try a thinner needle and go threough the sew cycle by hand, this can tell you a lot.
The thread is snapping because of all the needle breakages making the hole in the needle plate full of sharp edges, get rid of these by removing the needle plate and using strips of fine wet'n'dry paper to smooth them down. aceck the bobbin case for sharp notches too.
Get the timing fixed and your machine should be working ok
Mar 03, 2009 | Euro-Pro 473
Nov 20, 2008 | Janome 7034D Sewing Machine
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
