Question about Hardware & Accessories
Warburton franki timer switch model wf50
Need a instruction manual for set up of timer switch
5 Suggested Answers
  • 52 Answers
SOURCE: My timer won't cycle the motor on and off.
you may need trippers
Posted on Feb 26, 2010
SOURCE: vigoro 196-036 water timer manual
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Posted on Jul 12, 2011
SOURCE: Westinghouse photoelectric switch 28KC,# E257484 outdoor timer.
Here is the manual!
The Westinghouse 28451 is the exact same timer. I found the manual online.
Enjoy!!
Posted on Oct 29, 2011
  • 42190 Answers
SOURCE: I need to ask who can remove a WARBURTON FRANKI electrical timer on my property.
any properly qualified electrician should have the capacity to be able to do this
call one and ask the procedure
Posted on Aug 20, 2016
Aug 20, 2016 | Dryers
Warburton franki's phone number
go google and type in-- warburton franki company
there on the site you will find a contact us section and that will have phone numbers or e- mail where you can ask that question
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
I have an ET104CP and cannot read the instructions, therefore I need an instruction manual or the step to program one-(1) event both on and off.
Thank you for including model number of product.
-One confusing part of ET104CP 24-hour timer is that event1 is ON and event2 is OFF and event3 is ON, and event4 is OFF etc.
-Another confusing part is that on-line manual says: "Refer to programming instructions on time switch door."
-So if timer door has gotten wet or paper has aged, then key instructions are missing unless you have new timer in front of you.
-Last confusing part can be selector switches.
To program timer, selectors are set to Manual and RUN
To operate timer programs, selectors are set to AUTO and RUN
1) Manual for product appears below:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
2) According to manual, you put timer in Manual and RUN and then press and hold reset button, and then event1 will display.
Guessing at this point, press hour and minute button to set event1 ON
Press event button again to display event2, and then press hour and minute
Make sure events do not conflict with each other or timer will not operate
3) If instructions in #2 above are not correct, then add a comment and write out what is printed on your timer door, I can work alongside you to help decipher
4) If timer instructions on door panel have gotten wet and are unreadable, then contact Intermatic directly.
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 15, 2011 | Intermatic INC ET104CPD82 24 HOUR...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Here is the manual!
Enjoy!!
Nov 29, 2009 | UPM Programmable Outdoor Timer
Hardware & Accessories Logo
205 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
