Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Viper 478v remote won't arm / disarm alarm
I have a Viper 791XV using a 478V/P/C remote. The system started acting flakey. At first I had to press the arm or disarm button on the remote several times to get the system to arm / disarm the alarm. Now it has become so unreliable that I'm no longer using the system. The remote says it is sending the signal, but then it chimes that it did not receive a response from the alarm unit. I can still use the aux button to pop the trunk reliably, with no problems. Is my remote going bad?
ltfrc
  • 227 Answers
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Posted on Jan 17, 2009
jpk528
  • 95 Answers
SOURCE: when i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
Posted on Feb 16, 2009
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Posted on Aug 19, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
SOURCE: My Viper 791xv remote isn't receiving the page
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
Posted on Jan 19, 2010
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The car itself does not beep when the alarm is armed or disarmed
An output wire is not connected, you'll need to connect the brown wire on the 12 pin harness to the siren, it will be pin number 10. Either that or your siren is bad.
Oct 08, 2009 | 791XV The 791XV is a 2-way Security and...
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to turn up volume on siren. 791XV
I dont think you can turn it up. But I added 2 more sirens. The original is very small and quiet.
Apr 12, 2009 | 791XV The 791XV is a 2-way Security and...
When i arm the car how can i hear the sound viper on
Feb 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
Driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Dec 02, 2008 | 791XV The 791XV is a 2-way Security and...
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
174 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
