Question about Vehicle Parts & Accessories
Just purchased a used car with Viper CE8090 remote start a blue light keeps flashing in rear view mirror when the remote locks it.Is that normal.
  • 22 Answers
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Posted on Dec 04, 2008
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
SOURCE: Can you lock the viper 5301 keypad?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
Posted on Nov 18, 2009
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
Posted on Nov 27, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
There is a blue light flashing on rear view mirror. Why?
Usually a flashing blue light is from an aftermarket installed alarm system or remote starter.
You may want to check your owners manual if the light is in the mirror glass.
Feb 21, 2015 | 2009 Hyundai Accent
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
My Viper 5701 has been flawless but now on locking/unlocking the car no longer "chirps." Everything else still works perfectly such as the flashing lights. The remote also has changed its noise from the...
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
Jul 27, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
118 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
