The plate amps are bad in my polk rt1000p speakers
    Top Expert:
  • Audio Player... Master
  • 35,673 Answers
Repair or replace
Posted on Dec 02, 2012
  • JOHN HELMS Dec 04, 2012
    Thanks but they cost more then the speakers are worth and would still be the weak spot.. I tried a simple passive xover and they don't sound too bad.
I have polk audio rm 705 purchased from my friend a month ago. these are working fine but one day one speaker just have very low sound coming from tweeter where as the main speaker is silent.
Try switching the speakers left to right. If the same speaker is bad on both channels, the speaker is bad. If the good speaker is now bad, the unit driving the speakers is bad.
May 23, 2015 | Polk Audio Rm705 5.1 Channel Home Theater...
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
Do i need a amp?
Yes just need a wire adapter
Apr 23, 2014 | Polk Audio DB6510 Car Speaker
Which amplifier plate can use for Polk Audio PSW 1000
call parts express tell them your problem and they do have a plate amplifier that will work actually it's a better amp with more power.
Jun 14, 2012 | Polk Audio PSW1000 Subwoofer
5channel amp 6 speakers how do i wire amp to speakers. channel 5 is a sub channel which i do not have my amp is a polk audio pa1100.5
if it is a 5.1 channel amp wire the center speakers together into the same port. wire the two front speakers in the or der that they would appear on the amp (such as left front speaker to the left front speaker terminal on the amp etc.) and do the same for the rear speakers. and all you should have left is the sub-woofer channel in which you do not have to worry about.
Jun 03, 2011 | Polk Audio Car Audio & Video
Polk computer speakers work in laptop but not on desktop computer
desktops now a days have more than one plug for the speakers. try playing some music and play which hole works.
if there is a 5.1 or surround on the desktop then most likely the light green jack isnt stereo out but rather unamplified signal. thus when you plug head phones into it the internal amp drives the headphones, but wants the computer to drive the speakers.
try plugging it into the black one... or play pick a hole till it works.
Jun 10, 2010 | Polk Audio AMR2 Computer Speakers
No led on one Polk audio RT300P (bottom piece), but the top piece is ok. Is the power supply or crossover broken?
Hi have these speakers too and both crossovers in the bottom (sub) piece is not working. You may want to remove the amp assembly (8 screws?) and check the fuses before you send it in for repair there should be two of them. Polk no longer makes these units so they will most likely ask you to send it in for a repair estimate.
Jun 06, 2010 | Polk Audio RT3000P Speaker
If the power light on this 1200.1 polk amp turns
i had an amp that did the same thing your amp should not be doing that i dont know how old it is but mine had internal overload switch in it which kicked on if the amp was getting to hot and in my case i would say it was because of i had the amp bridged to a set of of some 100rms 4ohm speakers very nice speakers but by bridging the amp i was over loading the ohm load to the speakers and that was cause of my amp light staying the color that its was it was an old alpine amp with duo B circuitry but i hope you get your situation with this amp straited out check your contecions and if its bridege make sure the amp itself is not over heating cause that can be a problem you dont want mess with that.
Oct 27, 2009 | Polk Audio PA1200.1 Car Audio Amplifier
No sound comes out of the subwoofer. Sound passes through and the power light is on, but no subwoofer sound. Any ideas? Fuse? Easy fix? Can this subwoofer be replaced? is it still available? Can I buy a...
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
Aug 02, 2009 | Polk Audio PSW50 Subwoofer
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
157 people viewed this question
 Grubhead
Grubhead
