Question about Refrigerators
I have a Haier AES44VS small refrigerator that won't get cold. The light is on, I can hear the thermostat click on, and there is a faint hum in the condenser. I can hear the relay click on, for
Testing shows 120 volts to the unit. When contacts are placed on the relay connections the Ohms blink between 20-30 and around 180.
Bob Gemmell
  • 209 Answers
SOURCE: Beverage Air UR30GE Won't Get Cold.
If the thermostat has been bypassed it sounds like lack of refrigerant gas in the system. The level cant be checked visually, it will need to be checked by an engineer with pressure gauges.
Posted on Sep 28, 2007
SOURCE: whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Posted on Oct 22, 2007
SOURCE: GE Refrigerator Compressor Inop.
I found this post by searching on the capacitor number, JSU21X126AQC. My 2001 Kenmore refrigerator (don't have model# here) compressor didn't run, but I heard it hum for a few seconds and then a click. That's the Klixon overload doing its job. I measured resistance of the compressor leads same as original poster. This lead me to determine that the windings were not open or shorted. The wiring to the compressor also fed the condenser fan, and it was running, so power was at least all the way to the compressor.
What I did find was that the 12uF capacitor was only 4uF. My digital volt meter has a capacitor check range. This compressor circuit is a permanent split capacitor type. Without the proper capacitance, the compressor can't start. I replaced it with a 10uF, 220v AC capacitor I had, and now it runs fine. I wonder how many refrigerators are scrapped because of this inexpensive problem?
Posted on Jan 07, 2009
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
Won't cycle
That would be the thermostat. Can order online.
May 12, 2013 | Haier Refrigerators
Problem with GE Refrigerator (GTS18SHSVRSS) -- Doesn't run. Power seems to be getting in (inside lights turn on and we can hear a faint humming sound), but the fan/condenser doesn't seem to be...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 11, 2011 | GE (GTS16BCS) Top Freezer Refrigerator
Freeze is not freezing
Good day!!!
If the refrigerator isn't cool, check to see if the light comes on when you open the door. Next check to see if the thermostat is set properly. If both of these are OK, then check to see if the compressor is running. See if the compressor motor is running. The compressor is in a case with no visible moving parts. It is usually located at the back of the refrigerator near the bottom. If it's humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components.
Refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. If the compressor starts, replace the defrost timer. For further help, you'll want to call a professional appliance repair technician.
Sometimes you can hear a click-buzz-click sound coming from the compressor. This is the relay/overload at work. If you hear this, power is getting to the compressor. If you do, something is wrong with either the compressor or the compressor starting components. If you have a newer model with solid-state starting components, you may not hear anything at all. If there is power to the starting components, you may be able to test each part and replace any bad parts. There is also a 3-in-1 unit that may work on your model which replaces all the components in one unit. If the compressor still won't start, you have a bad compressor and need to replace it. If it does start, wire the 3-in-1 part in permanently. Make sure the one you buy is rated for the horsepower of your appliance.
If you don't hear anything, you can take the cover off the side of the compressor and test for voltage at the two leads. If no voltage is present, it's time to check the cold control. To test if the cold control is bad, you can temporarily jump the two wires at the cold control. If you get power to the compressor after doing so, the cold control needs to be replaced.
I hope this information will be helpful..Thanks for using fixya
Sep 09, 2011 | GE GSS23SGSSS Stainless Steel Side by Side...
Power went out. Hooked up to generator. Power came back on. Plugged back into wall. Have pwr thru fridge. Not cooling. Any thoughts? Nick
Good day!!!!!
I hope this information will be helpful..Thanks for using fixya..
Aug 31, 2011 | Refrigerators
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
Model hsw02c, 1.8 cuft compressor hums and then i hear a click and it doesnt do anything
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Haier HSW02 Compact Refrigerator
Can hear motor working turned up fully stillnot
Be sure what you hear is not the fan instead of the compressor. Unplug the unit, wait 10 minutes, and plug it back in. Listen for the compressor to start up, or even listen for a faint "hum and click" sound. That would be the compressor trying to start.
Jan 06, 2010 | Frigidaire FRS26ZSG
Light is on and thats it
Check to see if the compressor is hot. be carefull it can get really hot if its malfunctioning. If it is not hot then maybe the breaker switch on it does'nt reset anymore. Try replacing that.
Jun 28, 2009 | Haier HSL04WNBSS Compact Refrigerator
Not keeping things cold
check to see if the compressor is running in a cycle. if the compressor is not cycling, you will need to replace the compressor and fan.
if the compressor is humming, it because of a faulty motor and relay(start device). replace the compressor unit in this case.
May 22, 2009 | Haier HRF10WNB Top Freezer Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
