Question about Whirlpool GD5SHAX Side by Side Refrigerator
New side by side with icemaker, no manual
Is it ok to run fridge/freezer without the water being connected up? model : 6GS2SHQXRQ
thanks Donna
6GS2SH QXRQ
6GS2SH QXRQ
    Scholar:
  • 89 Answers
Yes perfectly ok. Just remember to clean the ice maker area well befor you use it.
Posted on Jan 11, 2009
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
GE GSH22JFR side by side refrigerator
Yes the water line has frozen in the door. There is a kit to repair this WR49x10173
Feb 09, 2010 | GE GSH22JFR Side by Side Refrigerator
Our kenmore side by side is leaking water into the bottom of the freezer how do I find where it is coming from and repair?
Most of the time that problem is caused by your drain hole in the freezer being blocked up with food or trash....or sometimes ice. Every 8, 10, or 12 hours depending on your defrost timer you fridge will defrost itself and drain the water under the fridge to a pan. If that drain is plugged then the water runs into the bottom of the freezer and sometimes will leak out onto the floor of your house. Another thing that it could be is the icemaker. Make sure the icemaker is not spilling water all over. If your icemaker is working ok, and there is not icecicles all over then rule out the icemaker. I would bet it's your drain.
Sep 11, 2009 | Refrigerators
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is almost always running....
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Feb 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Items in freezer melting, Ice maker empty, fridge feeling warm
hi there,
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Oct 10, 2008 | Kenmore Freezers
Model number: KSRB25FHSS05
hi .thanks for the question .is the fridge on, is it running. if not. it could be in defrost mode .if it is running .pull freezer from the wall, remove back panel ,clean all coils. thanks the appliance doc
Sep 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer not cool enough and the Icemaker not working
Defrost the fridge freezer for 24 hrs and before turning on check for any water leaks. Turn back on if the cabinet pulls down to temp in 12hrs you probably have a defrost heater problem if it doesnt pull down at all it could be the fan or sensor fault. Either way you would be best to contact a suitable refrig engineer. Hope this helps. fishersofcambridge
Aug 06, 2007 | Amana SXD524VW Side by Side Refrigerator
Whirlpool GD5SHAX Side by Side Refrigerator Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
