Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Castle garage door opener program remote - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
  • 3 Answers
SOURCE: garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Posted on Jan 17, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Posted on Feb 08, 2010
  • 3197 Answers
SOURCE: I have Craftsman TX2028 remotes (139.53753) with
Make sure the green light in the wall control is not blinking. If it is, press and hold the 3 seconds the lock button.
Posted on Nov 29, 2010
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
May 21, 2016 | Building Materials
About a remote for a garage door opener, how to program it.Bought a new remote and programmed it and now the old one don't work. How do you reprogram the old one?
The same way you programed the second one.
DO NOT hold the learn button down, just press it once and release it. Then press the button on the garage door remote and it will program to the garage door opener. Do the same for anything else you want to program to the garage door opener. When you hold the learn button down it erases all of the learned codes and you have to start over.
Feb 19, 2015 | Building Materials
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Cant program remotes to my garage door opener
It sure sounds like you might have a logic board problem but first make sure you are programming it like this.
Hold down the button on the remote and then press and immediately release the smart/learn button. Do this for each remote. The key is the word immediately. If you hold it in it will erase the one you just programmed.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Neighbours remotes open my garage door
It is very important to erase the memory of your unit and then reprogram your remotes. Erase the memory by holding the smart/learn button in for 6 seconds. None of your remotes or wireless keypad will work. Now program your remotes this way. Press and hold the button down on your remote and then press and immediately release the smart learn button.
If you have a wireless keypad program it like this. Press and immediately release the smart/learn button and then walk over to your keypad and key in your 4 digit code.
I would make sure your neighbor isn't using his opener when you are programming your keypad.
Oct 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Setting garage door opener
Most openers are programmed the same. You normally program the house garage opener to accept the new remote. Your garage opener will have a button to press to add in a new remote. Normally you press this and then press the remote in the car and hold until your lights on your opener flash or the garage door closes. (check your manual on your garage door opener)
Mar 27, 2009 | 2005 Chevrolet TrailBlazer
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
193 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
