Question about Sanyo DS32830H 32" TV
How to know what is good or bad - Sanyo DS32830H 32" TV
    Master:
  • 879 Answers
What is your question? Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best. Sometimes, it might have an answer to your question.
Posted on Dec 02, 2012
Has no oil pressure i drove it over ten mile still runs good but no oil pressure
Just because it runs good is no reason to drive it into the ground. No oil pressure can ruin an engine fast. Hopefuly the reason no oil pressure is the sensor is bad, it's connection is corroded and thus bad. If mine I would take it to a shop and have them actually measure the oil pressure with a mechanical gauge. If no oil pressure that way, you know you have a serious problem. If the mechanical measurement is good, then you know that The sensor is bad, it's connection is bad, or the oil pressure light or ? gauge
is bed on the dash panel. Good luck.
Mar 15, 2015 | 2007 Chevrolet Tahoe
Has no spark,plug wet with fuel, probably the coil but havent tore into yet & didnt know if there was any common problems?
If you know that the plug is good, then you are correct. It is a bad coil.
Blue spark is good
White spark is not so good
NO spark, well you know....NOT good.
Good Luck!
Jim
Aug 10, 2011 | Garden
I have a 2430 Hp and with the error message 52.00. I have reseated the connections and same error message appears. I have swapped the Laser/scanner with known good one -still same error message. Put back...
Did you change the parts one at a time or all at once?
I think that you swapped the laser/scanner from good printer to bad and it still failed. And then you put original back in bad printer, but didn't put it in the good printer and test it there. And then you swapped out the ECU. Bad printer still bad. You then put original ECU back in bad and then put the laser/scanner and the ECU in the good printer. Now you test the good printer and now fails with the same error as the bad one.
Now you don't know which of the parts in the good printer got wiped out in the bad one. In fact both of the parts could now be bad.
There's a lesson here somewhere.
Dec 09, 2010 | HP LaserJet 2430 Printer
Screen has gone very fuzzy all
Try another known good working monitor on your computer, if the screen looks good then you know the monitor is bad. If the known good working monitor looks fuzzy as well then you know the video card is bad on it and would need to be replaced.
Apr 28, 2010 | Computers & Internet
Our wii is pluged in and will not even turn on. The light on the front is not even on.
Try different outlets in the house to see if its just one bad outlet.
Also if you get to a know good working outlet plug in the AC Adapter and see if you get the light to come on the adapter. If you do then you know the outlet is good.
If you don't get a the light to come on the AC Adapter, then you know that the AC Adapter is bad and would need to get another one.
If the AC Adapter is good then you know its a problem with the main board inside of the Wii and that would need to be replaced.
Dec 02, 2009 | Nintendo Wii Console
1997 Dodge Stratus, 2.5L 4 cyl engine. Engine diagnosis from a trouble reader = cylinder 3 misfiring. The plug and spark plug wire are good. I don't know how too test the electronic ignition or the fuel...
Test the compression in that cylinder. Make sure you have the correct plugs, and good wires, as well as the cap and rotor button. If you have good compression, and the plugs and all are good, I would suspect either a bad fuel injector, bad head, or a bad distributor.
Aug 12, 2009 | 1997 Dodge Stratus
I can't see the colour red on my monitor. it turns up as grey. it is dominant in green and blue
Hook up a different known good working monitor to the computer. If the good monitor works then you know its the original monitor that is bad.
If the good monitor gives you the same problem then you know its the video card at that point that is bad.
Let me know if the original monitor that is giving you the problem is an old crt monitor or if its a newer LCD monitor?
Jul 04, 2009 | LG Computers & Internet
Ballast on samsung hlp4663w
The transformer can't damage the new lamp. Faulty transformers normaly take out the driving transistors or the fusible link in the power supply, if these are good then just replace the lamp. Espacially if you know the lamp is bad (test it by swapping with the others if unsure)
May 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
The computer has lost all the red color and others
Hook up another known good monitor to the video card and if it still has problems with red then you know the video card is bad and needs to be replaced.
If the known good monitor still works after being hooked up to the video card then you know the original monitor is bad.
Let me know if I can be of further help.
Ben
May 14, 2009 | Gateway GT5220 PC Desktop
Sanyo DS32830H 32" TV Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
