Question about Cobra 148 GTL 120-Channels Base CB Radio
142 GTL no sound
Tried 3 working mics, no audio at all, AM or SSB. I hear a slight sound from the speaker. External speaker no sound either. TX is perfect, and I can see I am receiving by the meter swing, I've just got no sound. I suspect an audio chip went bad>
  • Chris Kurdt Jun 07, 2007
    No go, same thing. Since I'm pretty new at this, troubleshooting that is, what's the partnumber for the Audio IC chip so I can have it replaced?
I actually found the problem to this, a capacitor (10v) went bad, replaced it and it's perfect now! Thanks!
Posted on Jul 07, 2007
  • matt_lynch19 Oct 21, 2010
    which EXACT capacitor went bad? I'm having same problem with my 2000. I can hear only (very low) through the "aux" jack for sound and i can transmit audio perfectly and PA function transmits audio also but nuttin from headphones or speaker. I can also see signals comin in on meter i modulation meter swings when i talk. People can hear me fine but i cannot hear them.
Part number is TA7222P 10 pin in line chip with radio faceing you part side up look on right side of chassie tward the back it's mounted on the board but fastened to the chassie use heat sink compound on new one when replaceing it and that's only if your SEAKER checks out okay!
    President:
  • 3,130 Answers
Yeppers you have a common problem of the audio output IC being bad or a defective speaker. If there is an external speaker jack, try another speaker just to make sure. Good Luck
Posted on Jun 07, 2007
SOURCE:
I need wire 4 pin mic to a 5 pin mic cobra 142 Gtl?
you'll have to seperate the ground from the shield and then attach the rx,tx,and ground ,the shild then the ground thats on the shield.
Apr 30, 2014 | Connex Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
My cobra 142 gtl loses power about two minutes after keying the mic.
hi
it looks like the output stage is going hot (99%)
maby the swr is high end eficiancy is low
usualy on ssb the power is higher than on am
bernard
http://www.rylwy.com/
Aug 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 142 no audio
Check to make sure the ext speaker jack is not worn out. Even the internal speaker will not work if it is worn.
Jul 26, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
TX oscillation
Make sure your boots are switched off and run the radio off a good car battery before you start looking for problems inside the radio. This problem may clear or change characteristics when the supply is changed.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Jul 30, 2010 | Radio Communications
Cobra 142 gtl no audio on receive work on pa, an on ext spkr get talk back,,,,but there no talk back in radio.... no audio on int spkr. tx good...
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Dec 18, 2009 | Cobra Radio Communications
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
714 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
