How to reset my ubee modem to factory settings
Can't remember password and want to reset it all back to like it just came out of the box
4 Suggested Answers
dean66
  • 22 Answers
SOURCE: D-Link wireless router & Ubee modem - which router ports
All routers will have a in for you modem, but your outlets wont matter what you use they are normally numbered 1-4 or 1-5. you can use any outlet and your pc will pic it up, they dont have to be in order through the ethernet.
Posted on May 17, 2010
SOURCE: I want to set security setting on router but
Please confirm you press and hold the reset button while the router is plugged in.
Posted on May 07, 2011
damneddle
  • 1607 Answers
SOURCE: I can't remember my password and want to reset
Hello
Look at the back of your router and you will see a small reset button hole. You should press and hold it for about 10 seconds by using a pin. That will remove the password of your router.
Posted on Aug 23, 2011
Forgot my password
Did you change the password from the factory default? If not, try these three.
1. root/root
2. user/user
3. admin/cableroot
Otherwise, you can do a hard reset, by pressing and holding the reset button on the back for about 10 or 15 seconds.
You might want to check with your ISP before resetting it though, some require a technician to go out and set it up again.
Apr 23, 2014 | uBee New Ddm3513 Docsis 3.0 Cable Modem -...
Dont remember wi fi password
More information is required...such as Make, Model, Version, etc.
Dec 25, 2013 | Ambit Lot Of 20 ubee U10c019 Wireless...
What is the username and password for the brighthouse ubee
You are able to access some of the modem/router settings using the credentials:
User Name - "user"
Password - "user"
Without the quotes, of course. This will not give you complete access, however, it will allow you to modify a fair amount (not in my opinion) of settings and view various modem/gateway information pages.
Unfortunately, Brighthouse (BHN) is on their game, when it comes to locking certain features/settings from being changed by the consumer. Time Warner Cable (TWC) sold select areas to BHN some time ago. TWC is a bit more open to user changes.
For example, TWC and BHN both supply the modem/router Ubee DDW3611. TWC's supplied unit's configuration can be accessed by the customer through the 'User' account and the 'Admin' account. BHN, on the other hand, only allows the customer to access the configuration through the 'User' account-which limits the available configuration options.
TWC units may be accessed through the 'Admin' account using the following credentials:
User Name - Last 8 characters of the Ubee Modem MAC Address
Password - c0nf1gur3m3
For example: If your Ubee Modem MAC Address is "1C:6D:CB:14:D6:4A"
Your 'Admin' credentials would be:
User Name - CB14D64A
It is very unlikely that the aforementioned credentials will work to log in to the 'Admin' account for BHN supplied units. But hey, its worth a shot. Right?
Hope this helps.
-James.
Aug 12, 2013 | Computers & Internet
Dir-601 D-Link stopping working with my hughes net, how can I get it working again?
Is your Hughes net modem working - check by connecting directly to it using a LAN cable. New check the LAN cable from our modem to the router - try a new cable. Reboot both devices.
Login in using your browser and go to WAN settings and
the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
When all else fails, The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Jun 23, 2012 | D-Link D Link Dir 601 Wireless N Home...
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
How to retreive Wi-Fi WPA2 password which I forgot?
Hi there.
If you forgot your wifi password, all you need to do is reset your modem. Doing this will restore your modem to it's factory settings.
Find the reset hole, could be on the side, front or back of the modem. Unfold a paper clip and push the reset hole with the paper clip. Hold it down for about 10 seconds or until it turns off.
When you turn the modem on, it is already back to factory settings and it will no longer ask for a password.
Let me know what happens.
Thank you!
Sep 16, 2011 | Computers & Internet
I can't remember my password and want to reset modem. I followed instructions on resetting, but when I click on 'forgot password' it just takes me back to the previous page saying a password...
Hello
Aug 23, 2011 | D-Link DIR-615 Wireless Router
How do i reset my password on my modem? I haven't used it for about a year and a half and i can't remember the password... please help, it is a Belkin G Wireless Router
Thanks for the info.
That's quite a problem huh!
There is no such things you can change your password in your modem if you didn't remember it. But i do have one solution.
First, you must have to reset the modem to its default value. the default password there is "admin" without a quote. That, if your willing to reset your modem.
If you want to reset, then you must find the small button at the back of your modem, just press it for 10 seconds. But if you dont remember the IP address, then try this default Ip address: 192.168.1.1 192.168.0.1 192.168.1.0
Access your modem using this Ip address.
hope it helps.
Thanks
Jul 15, 2011 | Computers & Internet
Lost dlink dir 655 password
Default user is Admin and default password is blank. (Don't type anything)
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults. To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
From: http://www.scribd.com/doc/6254595/DLink-Dir655-Manual-Wireless-N-Router
May 29, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
3,088 people viewed this question
David Payne
David Payne
