Question about Hitachi Televison & Video
60 inch hitachi hd 11 years old got real blurry then weny off, makes a sound like it is going to come back on but has no picture or sound,
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If you mean it got 3d looking or colors skewed etc the problem is in the convergence circuit----got a model number?
Posted on Dec 02, 2012
  • cheryl echert Dec 06, 2012
    the model number is 65swx20b
    the serial number is v2l009394 if that is helfull
premtech
  • 934 Answers
SOURCE: Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Posted on Jun 04, 2007
SOURCE: Hitachi 60 in. 60V715 Yellow Haze
A friend suggested I use windex and clean the mirror,lens, and screen. Would that help?
Posted on Jan 03, 2008
  • 927 Answers
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Posted on Sep 06, 2008
Ecollier2012
  • 3459 Answers
SOURCE: philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
techman
  • 3130 Answers
SOURCE: 50 inch hitachi tv, shadow behind writing and crooked screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Posted on Jul 06, 2009
11 year old Hitachi H65G500 rear projection TV. Picture is very blurry and dark.
with that age it will need a good clean out, just and the mirrors cleaning, thats the first part, mabe needs a new bulb. and the color wheel will need looking into to make sure its not faded, you need a non smear cleaner, alcohol base, as it will dry better and lint free cloths, to clean the chamber out but dont use on the colour wheel as this will damage it, when its all cleaned then have a see how it displays, it should be better. lence is safe to clean with the alcohol cleaner. just make sure you don't dislodge anything, and take it slow removing the light chamber and mirrors.
Jan 24, 2018 | Hitachi Televison & Video
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
TV turns on but has no picture or sound.
Take it in to an authorized Hitachi servicer. ther are too many things that need to be checked .The difference in cost of parts could be $200- $300. Not something you want to guess at.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
52 inch
your convergence board may be going out its about a 100.00 part but about 300 to have it installed
Jun 23, 2008 | RCA P52926 52" Rear Projection Television
Hitachi lcd picture problem convergence issue
You need to contact an ISF certified calibrationist.
Apr 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi-picture goes out but can still have sound
If it is a Hitachi 60V500 LCD projection TV, then I would suspect the lamp being the problem.
Feb 02, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
