Question about Singer CE150 Futura SewingandEmbroidery Machine
Singer Futura CE-150 Error Malfunction? Threading is correct
The machine has worked perfectly for quite some time. Recently on a project the machine blinks and a annoying beep comes on. I have searched hours for a solution to no prevail. I threaded correctly and yet that error still occurs? I have read the manual online for suggestions, but still nothing helpful.
  • Becky Dec 07, 2015
    there are 2 thread tensions. one is on the top of the machine, the other is behind the U turn arrow where you bring the thread back up to the arm that goes up and down. Open up the case as though your going to change the light bulb, you can see where the thread goes threw that tension. Make sure that is catching on the small clip that is a tension. I wanted to throw my machine out because I was tying to fix the wrong tension. Now it works perfectly.
There are 2 thread tensions. one is on the top of the machine, the other is behind the U turn arrow where you bring the thread back up to the arm that goes up and down. Open up the case as though your going to change the light bulb, you can see where the thread goes threw that tension. Make sure that is catching on the small clip that is a tension. I wanted to throw my machine out because I was tying to fix the wrong tension. Now it works perfectly.
Posted on Dec 07, 2015
  • 1,263 Answers
Have you tried a thin piece of material ? if the material is too thick the machine senses the resistance and gives a bleep ?
regards
Posted on Dec 16, 2012
2 Suggested Answers
SOURCE: Singer Futura CE 150, Problem
I had this same problem for a while. How I fixed it is: take hold of the thread (between the spool & where it goes under the plastic covering) & give it a gentle but firm pull towards you. That will pull the thread into the sensors. I get this #19 error even when sewing & this fixes it everytime.
Posted on Feb 13, 2011
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
I purchased the Singer Futura CE-150. When I click on transmit to machine I do not get any response. I do not get the dialog box to pop up to allow me to sent to machine. I have uninstalled, I have check...
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps
Mar 20, 2011 | Singer CE-100 Futura Computerized Sewing...
My futura ce-100 keeps beebing and it lights up. it stops working and will not move on. how do i fix this.
Check the threading, especially in the clear plastic tension race at the top back of the machine. This is the part where the machine checks the thread is moving. If the thread breaks, or is not running correctly through that area, the machine thinks the thread is broken/run out and stops.
Nov 16, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Will only sew for 3 inches then the lights flash (19) and it stops sewing. Will sew another 3 inches and repeat......
check threading on upper thread, if correct then there is sensor error and must be taken to singer service person
Sep 24, 2009 | Singer CE-100 Futura Computerized Sewing...
I have a singer futura ce-250/ce-350 machine.
You need to do a tension test
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Oct 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Vista unable to install Futura software
I have installed my Futura CE 150 software but when I connect to the machine, I get an error message - saying the cable in not connected or power is off. Tried to repeat several times but its not working. Please help!
Sep 09, 2008 | Singer CE-100 Futura Computerized Sewing...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
KEEPS SHOWING A BROKEN TREAD ERROR MESSAGE. I CANOT FINISH A PROJECT! SINGER FURURA CE-150
I have a CE-250 and I was having problems getting this message. After doing some research, I discovered that it was the thread sensor not sensing the thread. Try rethreading it or cleaning out your sensor area. It works for me when I get this message
Apr 23, 2008 | Singer CE-100 Futura Computerized Sewing...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE150 Futura SewingandEmbroidery Machine Logo
361 people viewed this question
Top Singer Computers & Internet Experts
NOEL
NOEL
Are you a Singer Computer and Internet Expert? Answer questions, earn points and help others
