Question about Anne Klein AK Crystal Accented #108213MPTT Watch for Women
10/9416RGWT WATCH EXTENDER CLASP
NEED EXTENDER FOR WATCH BAND ROSE COLOR
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: need a watch band clasp extender
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to order parts from AK. Rate me, please.
Posted on Mar 18, 2010
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
BEVERLYHILLS POLO CLUB WATCH MEN
Put a screw driver in the hole on the clasp. It shouls flip up and then you can slide the clasp up and down the watch band.
Dec 26, 2012 | Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
I need a clasp extender for Anne Klein watch. 10/8213. This is a bronze colored watch.
Most watch companies will give out extra links with a purchase. I would ask the retailer you bought from first, and if no luck there, I would try AK direct at this link:
http://www.anneklein.com/Customer-Service/HELP,default,pg.html
Aug 18, 2010 | Watches
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
Need a watch band clasp extender
Mar 17, 2010 | Anne Klein AK Crystal Accented...
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Aug 13, 2008 | Movado 0604586 Wrist Watch
I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
For any hidden clasp band, see this web page (excerpt below):
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
Anne Klein AK  Crystal Accented #108213MPTT Watch for Women Logo
29 people viewed this question
Top Anne Klein Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
