Question about iClick Sohlo 7 MP3 Player
Iclick 256MB sohlo7 can't access files from windows xp computer
I have a sohlo7 that has Word files on it. I can see them on my Windows laptop, but can't on my XP desktop. Windows Explorer sees the device, but without any files except those from Microsoft Dynamics - a PDF, a spreadsheet, and some Flash demo files. How can I make the desktop see the device's files? Do I need to install anything on the desktop? Thanks,
SOURCE: iclick sohlo7 mp3 player problems
I reformated The diviece and now it works just fine
Posted on Aug 29, 2008
0 characters
1 Points
How can you figure out the administrator's login password on a windows xp computer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
Dec 01, 2012 | Samsung Yepp YP-T7JX MP3 Player
Cant install u-disk to pc
Do you have internet access with this computer?
If so, you should be able to google the brand and model number and find a driver to download.
I would give that a try.
There is no need to reinstall windows to fix this. The driver or inf file is damaged. Visit another computer with win xp, search for files named usbstor. Copy files usbstor.inf and usbstor.pnf into windows/inf folder and usbstor.sys into windows/system32/drivers. Now just search for new driver and that's it, usb storage will be recognized.
Car Transmissions
Jun 12, 2012 | MP3 & Digital Media Players
Why won't mp3 let me listen to music
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting music files to mp3 fileformat :-
Apr 17, 2012 | iClick DMP 7.0 MP3 Player
When i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: (
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | MP3 & Digital Media Players
I have lost the software to disney mix stick. Please help
Please confirm what operating system your computer runs (like Windows XP or Vista). Also, confirm if you are looking for its drivers or some other special software.
If your system is running Windows XP or Vista, you can simply plug the device in and it will automatically appear in Start > My Computer (or Computer). You can then simply drop your music files (such as MP3s) straight onto the device.
With regards.
Jul 08, 2009 | Disney Pirates Digital Mix Sticks MP3...
Don't know how to down load music from my mp3 to
plug in mp3 and there should be a window come up with what you want to do. choose rip music or download music. if you canplug it in and the computer finds your mp3 player. when it starts to play choose rip music. if it cannot find it look for your mp3 player on the internet and download instructions.
Mar 25, 2009 | iClick Sohlo 7 MP3 Player
Won't let me sync anymore
What i would recommend you to do is if you have windows xp to uninstall windows media player 11 and reinstall windows media player...if you already have 10 just upgrade to 11..
That should solve the problem
I hope that helps
Thank you
Mar 05, 2009 | SanDisk Sansa Fuze MP3 Player
Iclick sohlo7 mp3 player problems
borre el programa device cuando estaba borrando mis canciones como le hago para recuperarlo
Dec 21, 2007 | iClick Sohlo 7 MP3 Player
My mp3 player is broke.HELP!!!!!!!!!!
May be your mp3-player is USB 1.1 and your Windows has an USB 2.0 Controller -> Microsoft has a patch (file usbhub.sys).
Nov 08, 2007 | RCA Thumbdrive Player (256MB) MP3 Player
When I sync files to My mp3 player, it says "no file" when I diconnect.
I unchecked in the advanced sync setting the box to have windows media player create the drive hierarchy. Then I deleted all files on the player and did the sync again. This time only the mp3 files get written.
Jan 28, 2007 | iClick DMP 7.0 MP3 Player
MP3 & Digital Media Players Logo
63 people viewed this question
Top iClick MP3 & Digital Media Players Experts
Gyula Lacz
Are you an iClick MP3 and Digital Media Player Expert? Answer questions, earn points and help others
