Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer interior light on however, dryer panel will not function dyer will not come on
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You will need to replace the control board. This dryer is known for the board going out. Here is the board to order.
Posted on Dec 02, 2012
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
How do I open the front of my whirlpool lgb6000 dryer
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right.
Oct 27, 2009 | Whirlpool Dryers
I have a Kenmore 110 electric dryer, model # 96520110. The tumbler no longer rotates/spins. It still heats. I thought it was the belt, but was told that it has no belt and to check the "dog ear agitator"....
The person who told you "it has no belt and to check the 'dog ear agitator'" thought you were talking about a washer.
Your dryer does have a belt and the belt is probably off the pulley or broken. The procedure below describes how to disassemble and service the interior.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Pull out lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Sep 30, 2009 | Kenmore Dryers
Dryer belt broke how do I fix this ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Disconnect Power. Lift Cover on lint filter. Remove two screws Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
The link below will show how the belt travels on the pulleys-Good Luck:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dryer Belt Configurations for All brands
Aug 24, 2009 | Kenmore Dryers
Dyer
signal level for 10 seconds
Jun 06, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer
i have had that seam problem 2 times, i had two change te bord 8546219 the 2 times , i don´t know way these hapens
Jun 02, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
