Question about Emerson LC320EM9 32 in. LCD HDTV
My Emerson model LC320EM81 32" in flatscreen just turned off while watching it. The green on light will come on for a seocnd, but immediately turns off again. Can this be repaired?
SOURCE: EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Posted on Apr 29, 2008
  • 608 Answers
SOURCE: I have an Emerson TV Model #LC320EM9B about 1
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
SOURCE: my flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Posted on Dec 26, 2010
  • 8457 Answers
SOURCE: I have an Emerson LCD
Tries tv unplug,replug it back like about an hour later.The tv now it resetting itself back to factory setting should work again.If have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jan 11, 2011
bugoy31
  • 1238 Answers
SOURCE: My flatscreen won't turn on it keeps going red to standby
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Power supply looks like this:
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
Try to watch this video about capacitors and how to replace it...
I hope this solution will be helpful...
Thanks for using fixya...
Posted on Nov 29, 2011
Lg flatscreen 07 green light flassing wont turn on
Need the model number sounds like power supply possibly bad caps. But need the actual model number to assist further.
Dec 09, 2012 | Samsung HPN5039 50 in. Plasma HDTV
Good day!!!!
Nov 22, 2011 | Emerson LC320EM8 32 in. LCD TV
I have an Emerson LCD Flatscreen, model BLC320EM9 A. When I try to turn it on, whether it be with the remote or with the button on the TV, the green light indicates that it's turning on for a few seconds...
Jan 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
My flatscreen emerson tv will not turn back on.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
There is no picture, just sound.
I have a 32" Emerson that did the same time.
The problem with mine was one of the Power Inverter Transformer when out. It used 6 of them to power the LCD screen.
I believe yours will have more than 6 since it's a bigger screen.
The Power Inverter Board is all one piece, the best place to get one at a good price is Shopjimmy.com
Mar 18, 2009 | Emerson EWL3706 37 in. LCD Television
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM9 32 in. LCD HDTV Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
