Question about Water Heaters
Where can i get parts for the richmond rmtg 53 dvn gas tankless hot water heater
  • Water Heaters Master
  • 5,245 Answers
  • 154 Answers
SOURCE: I GET NO HOT WATER
needs drop tube or full replacement
Posted on Aug 01, 2009
mrhotandcold
  • 248 Answers
SOURCE: I have a richmond tankless water heater and its
1/overheat stat 2/ fan 3/diaphrapm valve 4/ micro switch check area around fan very small hose pipe for pinhole best of luck
Posted on Oct 30, 2009
SOURCE: i have a richmond tankless water heater
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
Posted on May 28, 2010
SOURCE: i have a richmond gas hot water heater model
lock out code....turn off unit for 1 minute (unplug) press both arrows and hold for 5-10 sec... then enter L R L L ... R L R R...that should reset it.
Posted on Jul 25, 2010
  • 67 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem with...
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 06, 2012 | Rheem Richmond
Our Richmond Tankless is showing a reading of a C2 error code. How do we fix this. Why is it doing this?
Before calling service technician, open following link for Richmond/Rheem troubleshoot resources including Rheem chat.
Error codes are considered start place for troubleshooting.
C2 11 is 'No ignition' or 'Gas is inadequate' or 'Ignition failure'
Error C implies ignition rod
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jun 18, 2011 | Rheem Tankless Hot Water Heater...
Please help me to download an instruction manual for a Rheem 24 continuous flow hot water unit. I cannot find mine. The Unit's serial number is-- DAUHO9A24. My immediate problem is that the hot water...
http://www.greatergoods.com/store/energy-savers/tankless-water-heaters/rheem-rtg-74-dvn-natural-gas-tankless-water-heater/prod_386.html
manual above.
I professionally recommend that you get a Plumber/Gasfitter, to check this over, as this isn't usual, and I wonder if there are not "Other" problems too... with anything that uses Gas one has a responsibility to the entire family to have it professionally checked over, in my humble view..
Mar 08, 2011 | Rheem Tankless Hot Water Heater...
I have a RMTG-53dvn piped in parrallel with a traditional water heater because I used to have two traditional in parallel. The unit never kicked on with no trouble code, so I piped in series with a...
I could see how it might not work in parallel. Much water would go thru the conventional heater, so there would be low flow thru the tankless.
Now, the tankless is getting hot water from the conventional. Try shutting the conventional heater's power source off so the water gets cold, then see what happens with the tankless.
Gary
Mar 05, 2011 | Rheem RTG-53DVN Direct Vent Natural Gas...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
May 16, 2010 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
218 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
