Question about Retail Supplies
Er-3231 sharp cash register power went out won't do anything now except flash weird stuff across screen can i reset or something where are the batteries located
  • 3 Answers
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Posted on Jan 26, 2008
Henru
  • 45 Answers
SOURCE: how to fix
hi JPOWER,
my problem in finding a solution to this problem is the fact that Casio doesn't allow anyone who isn't a Casio supplier to download the manual for the CE 3700.
I would firstly suggest that you cycle the power on the machine if you've not tried that already. To do this you need to power down the machine and physically remove it from its power source. Keep it powered down like this for 30s to 1min to allow the machine's memory to clear. Power it back up and try logging in now.
If this doesn't work and you still have the manual for the CE 3700, try looking up some section in it relating to the procedure to restore the machine to its factory settings. With the machine restored to its factory settings you'll be able to log into the machine as if you just bought it, with the down side of losing all the data acquired by the machine before the restore to factory settings was performed.
If this doesn't work either the possibility of physical damage to a electrical component of the register should be considered and could be verified by a electrical technician.
Hope you find this information helpful in solving the problem with your cash register and thanks for using the FixYa service
Kind regards
Posted on Mar 01, 2008
I hope you did not reset the machine in the aformentioned method. If you have a service key there is a way to clear the totals but not like a Samsung. It involves z1 z2 and some 900 codes.
Posted on Nov 20, 2008
SOURCE: My Cash Register Sharp ER-2386 show me just a 0
YOur register lost the program or it has no battery power and was left unpluged. If you do a master reset it will all come back. At the moment it is most likely the program is corrupted and needs a master reset. It is done by turning the key (if you have a service key) to the blind position and holing down the journal key and plugging the machine back in, oh yeah you are suppose to pull the plug first. then program in the time and date and what ever else you may wat
Chris
Posted on Jul 07, 2009
  • 159 Answers
SOURCE: I have sharp er-a420 it was in my garage for two
Most Sharp register, including the ER-A420, have a rechargeable battery mounted inside to hold all memory when the power goes out. It should last a few months, but two years is a bit much. This might get it going:
  1. Unplug from AC POWER.
  2. Turn the key to PGM.
  3. Hold down both paper feed keys (at top-left of keyboard).
  4. While holding those two buttons down, plug the power back in.
  5. Turn the key back to REG.
  6. Enter 1 CASH # to sign on as Cashier 1.
  7. Try a sale.
There is a strong chance this won't do the job, because the memory has been randomized by total loss of power when the battery died. Worse yet, the battery may be too far gone to ever take a solid charge again. If so, you probably need the help of a Sharp register dealer to replace the battery, totally clear all memory and reprogram it. It's probably worth the money; the -420 is an excellent little register.
Posted on Dec 24, 2009
Sharp cash register
digi puk number for 0149455894
Nov 08, 2013 | Casio Parts Cash Register PC Desktop
My Sharp XE-A106 Cash Register is showing ---- in the z/pgm mode and won't print my report
That means there is a password that was set for the Z operation , Enter the password and press AMt button
Jan 03, 2013 | Sharp XE-A106 Cash Register
My sharp ER_3100 wont operate it shows 00000000
The ER-3100 has a memory-protection battery soldered to the main board. It charges whenever the register is on, and when the register is off, it can hold the totals and programming for over a month.
But the ER-3100 is about 20 years old, and you battery has lost its ability to hold a charge. You need to have the battery replaced and the entire machine's memory cleared, then programmed. Don't do it. You need a new cash register. All the replacement machines are much cheaper, much faster, and much quieter than your old ER-3100.
Nov 25, 2011 | Sharp XE-A402 Electronic Cash Register
SHARP ER-A410 CASH REGISTER DRAWER WON'T OPEN
Does it open when you print a Z report? The most common problem with these was either the drawer wiring or drawer solenoid failing.
If anyone needs more information, the Sharp ER-A410 and ER-A420 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Oct 20, 2011 | Casio Parts Cash Register PC Desktop
How to Reset a Sharp er-a320 Cash Register
You will need the service key to try the service reset. You likely don't have one of these, as they don't come with the machine, but licensed service technicians will have them.
The easiest thing may be to speak to a local cash register company or contact Sharp directly to locate a local licensed technician.
May 05, 2011 | Office Equipment & Supplies
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
I have sharp er-a420 it was in my garage for two years. I like to reprogram my register. I think I need to reset my register, I do not know how. Manager?s key does not do anything. When I plug it in on the...
  7. Try a sale.
Dec 10, 2009 | Sharp XE-A402 Electronic Cash Register
My Cash Register Sharp ER-2386 show me just a 0 instead 0.00 How can i change it?
Chris
Jun 04, 2009 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
47 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
