Connections i want connect my 845gbv motherboard and pheripherals....details
    President:
  • 2,351 Answers
Hi alimon_vm,
Click on the link below for the Intel motherboard D845GBV.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=825&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21 Choose your operating system.
(For windows XP systems)
Scroll down to number 12. Click the link below to open the manual.
ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
You will need Adobe PDF reader to view the manual. If you do not have Adobe, click on the next link. Download & install Adobe.
http://www.adobe.com/products/reader/
The manual will show you how to connect your devices & set the bios settings. (This is a must needed item for connecting MB & devices). If you never installed a motherboard into a case before, suggest you check out a uTube video of how too!.
http://www.youtube.com/watch?v=x4Mx1n7qRTE
http://www.youtube.com/watch?v=CB1iIWtDpSI
uTube can help you install just about anything. Video is a must if this is your first install & need the finer details.
Good luck alimon_vm!
Mike
Posted on Jan 11, 2009
How to go integrate pheripherals in bios mode in ABV_VMboard
The Asus A8V-VM motherboard?
Socket 939 processor socket, VIA K8M890 motherboard chipset, uses DDR Sdram at 400MegaHertz? (PC-3200)
http://www.asus.com/Motherboards/AMD_Socket_939/A8VVM/
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#AMD_.2F_Intel_processors
Motherboard Manual,
http://www.asus.com/Motherboards/AMD_Socket_939/A8VVM_SE/#download
[ + Manual (5)
Scroll down,
Version E2928
A8M-VM SE User's Manual for English Edition (e2928) ]
Page 17 - Standard Interrupt Assignments
BIOS Setup - Page 1 (43 of 86)
Advanced Menu - Page 18 (60 of 86)
PCI PnP (Plug and Play) - Page 27 (69 of 86)
Regards,
joecoolvette
Jun 02, 2012 | Computers & Internet
I have Intel 845GBV motherboard & have external LAN card of D-llink, modem & LAN cable which all are in working condition. I also have the LAN drivers installed, but I can't able to connect to...
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also check all leads and connections make sure they are not faulty and have secure connections
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 25, 2011 | Intel 845GE Motherboard
What is the P7 connection for?
The P7 connection ( connectors ) are used for Input. It has various purpose and is totally user's choise of how they want to use the connection for.
More details about the P7 connection is given in below link
P7 Connection
More details about your Motherboard are below
MSI 745 Motherboard
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 06, 2010 | MSI 745 Ultra (MS-6561-010) Motherboard
D610 Dell Laptop
it seems to be a problem with motherboard as you said you have replaced power supply and ac adaptor , try disconnecting external pheripherals do a flea power it doesnot start then you will have to replace motherboard
Jan 09, 2010 | Dell (F2273) Motherboard
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
Having problem with motherboard
well installing software is not a problem you must install all the drivers for motherboard and also check the requirement of the software. may be the system or setting is not compatable with the s/w requirements.
Nov 08, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Bluetooth connectivity
If your PC can't findthe drivers for your bluetooth device then it has nothing to do with your phonebut your PC.
If you can’t sync withyour PC when you’re using the USB cable then try installing the Sony Ericsson PC Suite.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/p1i?lc=en&cc=gb
Jan 25, 2008 | Sony Ericsson P1i
Computers & Internet Logo
438 people viewed this question
David Payne
David Payne
