Question about Frigidaire Refrigerators
Wont get cold , fridgidaire #glh536eewo - Frigidaire Refrigerators
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Does the compressor run?
Posted on Dec 02, 2012
Affinity front loader wont drain
Blocked the pump try putting a cleaner through the machine,check pump for obstruction.
Jul 26, 2014 | Electrolux 134743500 Fridgidaire Washer...
Fridgidaire model gler331as2 drum wont turn with full load
The belt may be worn and slipping or the belt tension idler may be failing or broken
Sep 10, 2012 | Frigidaire GLER642A Electric Dryer
Fridgidaire dryer is just blowing cold air.
You either have a bad element, thermostat, thermal cut-off or a fuse.
May 08, 2012 | Dryers
My affinity fridgidaire wont complete a full cycle, it wont spin the clothes, it just stops. Help?
That would ether be your door lock or motor control board would need more info from you to pinpoint/bye for now...
Jan 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire CER3600AS0 dryer randomly shuts off. I usually only happens when its cold outside. It worked for 3 loads and the shut off with 10 minutes left and wont turn back on.
This could be anything from electrical connections to a ventilation issue. Contact a technician to come out and do a test on the connections. A dryer has ALOT of them.
Dec 14, 2009 | Frigidaire Dryers
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Do not get a cold water wash from front load fridgidaire only hot
most diswashers only hook from the left side under the sink which is hot, some dishwashers on hot make the water extra hot with the bottom element for pots and pans, sounds like your dishwasher is working properly, you need hot water to sterilize. Rob
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Refrigerators Logo
35 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
