I have Samsung LA32C400 LCD TV. Recently I reset the factory setting of the tv and now the screen is upside down.
5 Suggested Answers
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Posted on Jun 03, 2008
  • 210 Answers
SOURCE: how do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Posted on Oct 26, 2009
  • 210 Answers
SOURCE: Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Posted on Dec 13, 2009
I have a Samsung 40 led smart tv... Model number UN40D6000SF.. The problem I'm having is when the boot logo is upside down tv will flash on n off. What is wrong with it??
Samsung say you should try the factory reset option.
If that doesn't work it could be a fault on the main board. Sometimes this happens when boards are replaced.
There is also a service mode that allows you to flip the main screen. You can find how to access that by searching YouTube with the words "Samsung TV picture upside down".
Try the other options first though.
Apr 04, 2017 | Samsung Televison & Video
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
Picture is mirrored horizontally
Do a factory reset to this TV. Refer its user manual for details.
May 07, 2013 | Vizio XVT3D474SV 47 in. 3D LCD TV
I have Samsung LA32C400 LCD TV. Recently, some vertical lines appear on the screen, then colour changes, and sometimes the pictures doesn't move.
i have tv samsung model samsung lcd tv model la32c400...when you open the power on. they have a raster but it is hung .up...and then we open again the power booton on pwer it is have only light display ...and also based side have small line ruster only 3cm....what cause this and problem the t-conn....has fixed already in lcd or disposable .....what is the solution on this parblem......some help.....plssss txt me 09991375154 thank u.....
Jun 12, 2012 | Samsung LE Televison & Video
My samsung lcd ..two video channel input mixing problem
ok folks, for all of you with this kind of issue....
Firstly we need to reset the TV to the samsung factory settings, in order to do this we need to enter the engineers menu, you can do this by pressing the following buttons on the remote control while the tv is in standby.
INFO / MENU / MUTE THEN THE POWER BUTTON (NO PAUSES)
When the tv starts up you will then see the engineers menu. Scroll down to i think... number 12 which is RESET then press OK.
The tv will now power down and reset the Eeprom ic.
Turn the tv back on and retune etc.... then try your inputs again. All should then be OK.
Hope this helps everyone.
Please rate with thumbs up
Thanks
Nov 10, 2011 | Samsung LN46A650 46 in. LCD HDTV
Dec 13, 2009 | Televison & Video
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
How do i reset factory sttings on samsung lcd tv
Oct 25, 2009 | Samsung LN46B530 LCD TV
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
